[GeoNode-devel] GeoNode master: Is RabbitMQ and Celery now mandatory?
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Oct 9 00:55:13 PDT 2019
Not mandatory. Those are just warnings, however.
You can safely remove the JARs from GeoServer if you don't want to use
RabbitMQ.
Il giorno mar 8 ott 2019 alle ore 21:58 Paolo Corti <pcorti at gmail.com> ha
scritto:
> Hi devs
> I have noticed now that I see a lot of errors in a instance like this
> when uploading a layer - the layer gets still uploaded successfully:
> 2019-10-08 19:36:44,445 WARN [common.sender] - Error while trying to
> initialize RabbitMQ Sender Connecton
> java.net.ConnectException: Connection refused (Connection refused)
> at java.net.PlainSocketImpl.socketConnect(Native Method)
> at java.net
> .AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
> at java.net
> .AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
> at java.net
> .AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
> at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
> These errors are slowing down GeoNode and the upload process. Why do I get
> them?
> In my case I have ASYNC_SIGNALS set to False (default)
> thanks
> Paolo
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
> #drt3jc1
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20191009/8398fc5e/attachment.html>
More information about the geonode-devel mailing list
