[GeoNode-devel] GeoNode master: Is RabbitMQ and Celery now mandatory?
Paolo Corti
pcorti at gmail.com
Wed Oct 9 08:19:04 PDT 2019
Hi Alessio
I understand they are warnings but I am afraid that they are slowing
down the general GeoServer response.
I think we discussed this already, but can't remember exactly: are you
talking about the jars related to monitoring?
I see these two ones which could be related, are they the ones which
need to be removed?
gs-monitor-core-2.15.2.jar
gs-status-monitoring-2.15-20190717.093744-2.jar
thanks in advance!
paolo
On Wed, Oct 9, 2019 at 3:55 AM Alessio Fabiani
<alessio.fabiani at geo-solutions.it> wrote:
> Not mandatory. Those are just warnings, however.
> You can safely remove the JARs from GeoServer if you don't want to use RabbitMQ.
> Il giorno mar 8 ott 2019 alle ore 21:58 Paolo Corti <pcorti at gmail.com> ha scritto:
>> Hi devs
>> I have noticed now that I see a lot of errors in a instance like this
>> when uploading a layer - the layer gets still uploaded successfully:
>> 2019-10-08 19:36:44,445 WARN [common.sender] - Error while trying to
>> initialize RabbitMQ Sender Connecton
>> java.net.ConnectException: Connection refused (Connection refused)
>> at java.net.PlainSocketImpl.socketConnect(Native Method)
>> at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
>> at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
>> at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
>> at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
>> These errors are slowing down GeoNode and the upload process. Why do I get them?
>> In my case I have ASYNC_SIGNALS set to False (default)
>> thanks
>> Paolo
>> Paolo Corti
>> Geospatial software developer
>> web: http://www.paolocorti.net
>> twitter: @capooti
>> skype: capooti
>> #drt3jc1
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Paolo Corti
twitter: @capooti
skype: capooti
#drt3jc1
More information about the geonode-devel
