[GeoNode-devel] 2.10.x Installation Issue
Florian Hoedt florian.hoedt at thuenen.de
Mon Oct 21 00:04:04 PDT 2019
Hello Sachin,
Is GEOS properly installed?
What is the output of the following lines:
sudo apt update
sudo apt upgrade
sudo apt install libgeos-dev
where there any errors on:
pip install -r requirements.txt --upgrade --no-cache --no-cache-dir
cheers,
Florian
MSc Florian Hoedt
Koordinator Geoinformation | Coordinator Geoinformatics
OpenData Beauftrager | OpenData Representative
Thünen-Institut, Zentrum für Informationsmanagement | Thünen Institute, Centre for Information Management
Bundesallee 44
38116 Braunschweig
Tel: +49 531 596-1428
Fax: +49 531 596-1499
Mail: florian.hoedt at thuenen.de
Web: www.thuenen.de
Das Johann Heinrich von Thünen-Institut, Bundesforschungsinstitut für Ländliche Räume, Wald und Fischerei - kurz: Thünen-Institut - besteht aus 14 Fachinstituten, die in den Bereichen Ökonomie, Ökologie und Technologie forschen und die Politik beraten.
The Johann Heinrich von Thünen Institute, Federal Research Institute for Rural Areas, Forestry and Fisheries – Thünen Institute in brief – consists of 14 specialized institutes that carry out research and provide policy advice in the fields of economy, ecology and technology.
Von: "Sachindra Singh" <sachin1618 at gmail.com>
An: "geonode-devel" <geonode-devel at lists.osgeo.org>
Gesendet: Montag, 21. Oktober 2019 03:24:00
Betreff: [GeoNode-devel] 2.10.x Installation Issue
Following installation guide @ [ http://docs.geonode.org/en/master/install/core/index.html | http://docs.geonode.org/en/master/install/core/index.html ] using branch 2.10.x I get the following error during paver setup:
File "/home/ubuntu/.virtualenvs/geonode/local/lib/python2.7/site-packages/django/contrib/gis/geos/__init__.py", line 5, in <module>
from .collections import ( # NOQA
File "/home/ubuntu/.virtualenvs/geonode/local/lib/python2.7/site-packages/django/contrib/gis/geos/collections.py", line 9, in <module>
from django.contrib.gis.geos import prototypes as capi
ImportError: cannot import name prototypes
Running python manage.py gives the same error.
Please advice,
Sachin
geonode-devel mailing list
https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20191021/d0d96138/attachment.html>
More information about the geonode-devel mailing list
