[GeoNode-devel] GeoNode Project: Timeout updates Layer with new ManyToManyField in ResourceBase
Giambattista Mameli mameli.giambattista at gmail.com
Wed Oct 23 08:46:05 PDT 2019
Hi guys,
I finally solved the problem.
I was missing the last step in my implementation: convert the domain_area
array into a string before send it to GeoServer
Right now i modified the CORE of GeoNode, but i think i can move everything
on the GeoNode Project
On “geonode.social.signals”, i added the following to the function
“json_serializer_producer”:
    if 'domain_area' in dictionary.keys():
        keys = dictionary['domain_area']
        dictionary['domain_area'] = str(keys)
Thank you all for the help
gb.
Il giorno mer 23 ott 2019 alle ore 09:46 Giambattista Mameli <
mameli.giambattista at gmail.com> ha scritto:
> Hi Alessio and Amedeo,
> thank you very much for the answers provided.
> Amedeo, the answer is YES. The relationship is M:M and it can be done in
> both ways. I followed the "add_class" path because i do not want to modifiy
> the "CORE", and keep the implementations only on the Geonode Project
> Module. Since the ResourceBase is part of the CORE, i recall the class from
> the Project and add the new relationship...
> For the update: when i modify data i do not recreate the layer, but only
> the associated INFOs. The integrated authorization works well.
> Alessio, can you give me more hints about the "signal interception"?
> Il giorno mar 22 ott 2019 alle ore 15:39 Amedeo Fadini <amefad at gmail.com>
> ha scritto:
>> Hi Giambattista and welcome in the dev list
>> Thank-you Alessio for the quick response.
>> I have a question just to learn something new: is it the same  thing to
>> define the M2M relation on the new object side or use add_class to resource
>> base like in this class?
>> I see in Giambattista log the line
>> producer.geoserver_upload_layer(payload)
>> Giambattista: does the update operation imply the creation or replacement
>> of the layer related to domain_area?
>> If this is the case have you checked that integrated authentication
>> between geonode and geoserver is working as expected?
>> Amedeo Fadini
>> Il giorno mar 22 ott 2019 alle ore 11:20 Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it> ha scritto:
>>> Hi,
>>> most probably you are hitting the post-save signal on ResourceBase
>>> indefinitely.
>>> You should intercept the signal method and updating the resource base
>>> only in the case you are adding the the m2m relationship a new ResourceBase.
>>> Il giorno lun 21 ott 2019 alle ore 18:06 Giambattista Mameli <
>>>> Hi guys,
>>>> I developed a custom GeoNode Project implementing a M:M relationship on
>>>> the ResourceBase table
>>>> Here the steps:
>>>> 1) model creation of the new table
>>>> class DomainArea(models.Model):
>>>>     identifier = models.CharField('Domain Area name', max_length=255, unique=True)
>>>>     description = models.TextField(default='')
>>>>     gn_description = models.TextField(
>>>>         'GeoNode description', default='', null=True)
>>>>     is_choice = models.BooleanField(default=True)
>>>>     def __unicode__(self):
>>>>         return u"{0}".format(self.gn_description)
>>>>     class Meta:
>>>>         ordering = ("identifier",)
>>>>         verbose_name_plural = 'Domain Areas'
>>>> 2) add the relation between the ResourceBase table and the new created
>>>> table
>>>>         domainarea = models.ManyToManyField(
>>>>             DomainArea,
>>>>             related_name='resourcebase_domainarea',
>>>>             blank=True)
>>>>         ResourceBase.add_to_class('domain_area', domainarea)
>>>> 3) Add the function to handle the new value in the admin panel
>>>> admin.site.register(DomainArea)
>>>> All the steps work good, Django creates the new table with all the
>>>> relationship and I can handle via admin panel both values and associations
>>>> between domain areas and Layers/Docs/Maps.
>>>> The problem is when I modify these values.
>>>> After the first association, all the updates go wrong (timeout, even
>>>> with a very long timeout set).
>>>> This is the error message:
>>>> Traceback:
>>>> File
>>>> "/usr/local/lib/python2.7/site-packages/django/core/handlers/exception.py"
>>>> in inner
>>>>   41.             response = get_response(request)
>>>> File
>>>> "/usr/local/lib/python2.7/site-packages/django/core/handlers/base.py" in
>>>> _legacy_get_response
>>>>   249.             response = self._get_response(request)
>>>> File
>>>> _get_response
>>>>   187.                 response =
>>>> self.process_exception_by_middleware(e, request)
>>>> File
>>>> _get_response
>>>>   185.                 response = wrapped_callback(request,
>>>> callback_args, *callback_kwargs)
>>>> File
>>>> "/usr/local/lib/python2.7/site-packages/django/contrib/admin/options.py" in
>>>> wrapper
>>>>   552.                 return self.admin_site.admin_view(view)(*args,
>>>> **kwargs)
>>>> File
>>>> "/usr/local/lib/python2.7/site-packages/django/utils/decorators.py" in
>>>> _wrapped_view
>>>>   149.                     response = view_func(request, args, *kwargs)
>>>> File
>>>> "/usr/local/lib/python2.7/site-packages/django/views/decorators/cache.py"
>>>> in _wrapped_view_func
>>>>   57.         response = view_func(request, args, *kwargs)
>>>> File
>>>> "/usr/local/lib/python2.7/site-packages/django/contrib/admin/sites.py" in
>>>> inner
>>>>   224.             return view(request, args, *kwargs)
>>>> File
>>>> change_view
>>>>   1512.         return self.changeform_view(request, object_id,
>>>> form_url, extra_context)
>>>> File
>>>> _wrapper
>>>>   67.             return bound_func(*args, **kwargs)
>>>> File
>>>> _wrapped_view
>>>> File
>>>> bound_func
>>>>   63.                 return func.__get__(self, type(self))(*args2,
>>>> **kwargs2)
>>>> File
>>>> changeform_view
>>>>   1409.             return self._changeform_view(request, object_id,
>>>> File
>>>> _changeform_view
>>>>   1449.                 self.save_model(request, new_object, form, not
>>>> add)
>>>> File
>>>> save_model
>>>>   980.         obj.save()
>>>> File "/usr/local/lib/python2.7/site-packages/polymorphic/models.py" in
>>>> save
>>>>   83.         return super(PolymorphicModel, self).save(*args, **kwargs)
>>>> File "/usr/local/lib/python2.7/site-packages/django/db/models/base.py"
>>>> in save
>>>>   808.                        force_update=force_update,
>>>> update_fields=update_fields)
>>>> in save_base
>>>>   848.                 update_fields=update_fields, raw=raw,
>>>> using=using,
>>>> File
>>>> "/usr/local/lib/python2.7/site-packages/django/dispatch/dispatcher.py" in
>>>> send
>>>>   193.             for receiver in self._live_receivers(sender)
>>>> File "/usr/local/lib/python2.7/site-packages/geonode/decorators.py" in
>>>> wrapper
>>>>   53.                 return func(*args, **kwargs)
>>>> File
>>>> "/usr/local/lib/python2.7/site-packages/geonode/geoserver/signals.py" in
>>>> geoserver_post_save
>>>>   85.         producer.geoserver_upload_layer(payload)
>>>> File
>>>> "/usr/local/lib/python2.7/site-packages/geonode/messaging/producer.py" in
>>>> sync_if_local_memory
>>>>   71.                 worker.run(timeout=broker_socket_timeout)
>>>> File "/usr/local/lib/python2.7/site-packages/kombu/mixins.py" in run
>>>>   170.                     for _ in self.consume(limit=None, **kwargs):
>>>> File "/usr/local/lib/python2.7/site-packages/kombu/mixins.py" in consume
>>>>   192.                     conn.drain_events(timeout=safety_interval)
>>>> File "/usr/local/lib/python2.7/site-packages/kombu/connection.py" in
>>>> drain_events
>>>>   315.         return self.transport.drain_events(self.connection,
>>>> **kwargs)
>>>> File
>>>> "/usr/local/lib/python2.7/site-packages/kombu/transport/virtual/base.py" in
>>>> drain_events
>>>>   966.                     raise socket.timeout()
>>>> Any help will be greatly appreciated
>>>> Thanks in advance
>>>> _______________________________________________
>>>> geonode-devel mailing list
>>>> geonode-devel at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>> GeoServer Professional Services from the experts! Visit
>>> http://goo.gl/it488V for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> Founder/Technical Lead
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>> phone: +39 0584 962313
>>> fax:     +39 0584 1660272
>>> mob:   +39 331 6233686
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>> This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
> Giambattista Mameli
> Web Developer, WebGIS
> E-mail: info at giambattistamameli.it
> Web: http://www.giambattistamameli.it
Giambattista Mameli
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20191023/62b26486/attachment-0001.html>
More information about the geonode-devel mailing list
