[GeoNode-devel] errors with style creation during layer upload to PostGIS
Paolo Corti
pcorti at gmail.com
Wed Sep 4 14:10:15 PDT 2019
Looking in the GeoServer log, it appears that GeoNode upload fails to
create the style (and then the layer) in step 7 because it cannot find
the newly created GeoServer layer (even if this was already created at
step 4 in the upload process). This is the error I see in GeoServer:
2019-09-04 21:05:42,632 ERROR [geoserver.rest] - No such layer: geonode:rivers
org.geoserver.rest.ResourceNotFoundException 404 NOT_FOUND: No such
That looks like a regression? Or some configuration which is not correct?
In my case I am using DELAYED_SECURITY_SIGNAL set to True.
thanks
Paolo
On Wed, Sep 4, 2019 at 5:01 PM Paolo Corti <pcorti at gmail.com> wrote:
> Hi devs
> I am experiencing the following issue on an instance using GeoNode
> master from a GeoNode project and PostGIS as a datastore. When
> uploading a layer, I see the following
> error message:
> >>> Step 7. Creating style for [rivers]
> Traceback (most recent call last):
> File "/home/ubuntu/geonode/geonode/geoserver/helpers.py", line 246,
> in get_sld_for
> _default_style = layer.default_style
> AttributeError: 'FeatureType' object has no attribute 'default_style'
> File "/home/ubuntu/geonode/geonode/geoserver/helpers.py", line 255,
> in get_sld_for
> name = gs_layer.default_style.name if gs_layer.default_style is
> not None else "raster"
> AttributeError: 'NoneType' object has no attribute 'default_style'
> after that, the layer is created in Django but not in GeoServer. Any
> hint why this could be happening before I debug it on my own?
> I noticed that after restarting GeoServer the layer is again uploaded correctly.
> Paolo
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
> #drt3jc1
Paolo Corti
twitter: @capooti
skype: capooti
#drt3jc1
More information about the geonode-devel
