[GeoNode-devel] Docker build issues
    Francesco Bartoli
    xbartolone at gmail.com
    Thu Sep  5 02:31:16 PDT 2019
Hello Pieter,
glad you have solved. However, were you using master or a different version? I remember we had that variable COMPOSE_CONVERT_WINDOWS_PATHS to keep loading unix docker socket in Windows some time ago (See discussion https://github.com/GeoNode/geonode/issues/3709). Recently it has been removed as we are no longer mounting that socket.
Thanks
Francesco
Il 4 set 2019, 19:04 +0200, Pieter du Plooy <pjduplooy.gis at gmail.com>, ha scritto:
> Hi Florian and others.
> Uninstalled Docker Toolbox and Virtualbox, and installed again.
> Geonode now works, dunno why...
> Anyway.
> Thanks
> Pieter
> > On Wed, Sep 4, 2019 at 8:34 AM Florian Hoedt <florian.hoedt at thuenen.de> wrote:
> > > Hello Pieter,
> > > This is most likely a windows path issue. All paths are written in unix style.
> > > I had these issues as well and just left using docker on windows, but creating a virtual linux machine which will run docker for me. A box in a box, which is not perfect but works.
> > > https://forums.docker.com/t/docker-toolbox-and-windows-paths/60392/2
> > > @frafra @francbartoli: what do you say?
> > > cheers,
> > > Florian
> > > MSc Florian Hoedt
> > > Koordinator Geoinformation | Coordinator Geoinformatics
> > > OpenData Beauftrager | OpenData Representative
> > > Thünen-Institut, Zentrum für Informationsmanagement | Thünen Institute, Centre for Information Management
> > > Bundesallee 44
> > > 38116 Braunschweig
> > > Tel:  +49 531 596-1428
> > > Fax:  +49 531 596-1499
> > > Mail: florian.hoedt at thuenen.de
> > > Web:  www.thuenen.de
> > > Das Johann Heinrich von Thünen-Institut, Bundesforschungsinstitut für Ländliche Räume, Wald und Fischerei - kurz: Thünen-Institut - besteht aus 14 Fachinstituten, die in den Bereichen Ökonomie, Ökologie und Technologie forschen und die Politik beraten.
> > > The Johann Heinrich von Thünen Institute, Federal Research Institute for Rural Areas, Forestry and Fisheries – Thünen Institute in brief – consists of 14 specialized institutes that carry out research and provide policy advice in the fields of economy, ecology and technology.
> > > Von: "Pieter du Plooy" <pjduplooy.gis at gmail.com>
> > > An: geonode-devel at lists.osgeo.org
> > > Gesendet: Dienstag, 3. September 2019 20:38:16
> > > Betreff: [GeoNode-devel] Docker build issues
> > > Hi guys.
> > > Using docker toolbox (Win 7).  Just cloned the repository, and get the following error on build:
> > > Step 8/9 : EXPOSE 8000
> > > ERROR: Service 'django' failed to build: error creating overlay mount to /mnt/sda1/var/lib/docker/overlay2/645283667aeba9f90420f12e8d0c381f365397b0e083783d75bfa
> > > 4a5fbbf6b21-init/merged: no such file or directory
> > > I am using the following command:
> > > $ docker-compose -f docker-compose.yml -f docker-compose.override.192.168.99.100.yml up --build -d
> > > Dont know what to do know.
> > > Machine configuration havent changed since previous build..
> > > Pieter
> > > _______________________________________________
> > > geonode-devel mailing list
> > > https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190905/81c89c56/attachment.html>
More information about the geonode-devel
