[GeoNode-devel] Docker build issues
Pieter du Plooy
pjduplooy.gis at gmail.com
Thu Sep 5 07:54:05 PDT 2019
Hi guys.
Using the older Docker Toolbox (Win 7 machine, so cant use Docker for
Windows). The COMPOSE_CONVERT_WINDOWS_PATHS system environment variable is
automatically setup on install of Docker Toolbox.
Anyway, I'm glad it worked.
Thanks a lot for all the replies and help
On Thu, 05 Sep 2019, 11:31 Francesco Bartoli, <xbartolone at gmail.com> wrote:
> Hello Pieter,
> glad you have solved. However, were you using master or a different
> version? I remember we had that variable COMPOSE_CONVERT_WINDOWS_PATHS to
> keep loading unix docker socket in Windows some time ago (See discussion
> https://github.com/GeoNode/geonode/issues/3709). Recently it has been
> removed as we are no longer mounting that socket.
> Thanks
> Francesco
> Il 4 set 2019, 19:04 +0200, Pieter du Plooy <pjduplooy.gis at gmail.com>, ha
> scritto:
> Hi Florian and others.
> Uninstalled Docker Toolbox and Virtualbox, and installed again.
> Geonode now works, dunno why...
> Anyway.
> Thanks
> Pieter
> On Wed, Sep 4, 2019 at 8:34 AM Florian Hoedt <florian.hoedt at thuenen.de>
> wrote:
> Hello Pieter,
> This is most likely a windows path issue. All paths are written in unix
> style.
> I had these issues as well and just left using docker on windows, but
> creating a virtual linux machine which will run docker for me. A box in a
> box, which is not perfect but works.
> https://forums.docker.com/t/docker-toolbox-and-windows-paths/60392/2
> @frafra @francbartoli: what do you say?
> cheers,
> Florian
> MSc Florian Hoedt
> Koordinator Geoinformation | Coordinator Geoinformatics
> OpenData Beauftrager | OpenData Representative
> Thünen-Institut, Zentrum für Informationsmanagement | Thünen Institute,
> Centre for Information Management
> Bundesallee 44
> 38116 Braunschweig
> Tel: +49 531 596-1428
> Fax: +49 531 596-1499
> Mail: florian.hoedt at thuenen.de
> Web: www.thuenen.de
> Das Johann Heinrich von Thünen-Institut, Bundesforschungsinstitut für
> Ländliche Räume, Wald und Fischerei - kurz: Thünen-Institut - besteht aus
> 14 Fachinstituten, die in den Bereichen Ökonomie, Ökologie und Technologie
> forschen und die Politik beraten.
> The Johann Heinrich von Thünen Institute, Federal Research Institute for
> Rural Areas, Forestry and Fisheries – Thünen Institute in brief – consists
> of 14 specialized institutes that carry out research and provide policy
> advice in the fields of economy, ecology and technology.
> *Von:* "Pieter du Plooy" <pjduplooy.gis at gmail.com>
> *An:* geonode-devel at lists.osgeo.org
> *Gesendet:* Dienstag, 3. September 2019 20:38:16
> *Betreff:* [GeoNode-devel] Docker build issues
> Hi guys.
> Using docker toolbox (Win 7). Just cloned the repository, and get the
> following error on build:
> Step 8/9 : EXPOSE 8000
> ERROR: Service 'django' failed to build: error creating overlay mount to
> /mnt/sda1/var/lib/docker/overlay2/645283667aeba9f90420f12e8d0c381f365397b0e083783d75bfa
> 4a5fbbf6b21-init/merged: no such file or directory
> I am using the following command:
> $ docker-compose -f docker-compose.yml -f
> docker-compose.override.192.168.99.100.yml up --build -d
> Dont know what to do know.
> Machine configuration havent changed since previous build..
> Pieter
> geonode-devel mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190905/953a93ee/attachment.html>
More information about the geonode-devel
