[GeoNode-devel] errors with style creation during layer upload to PostGIS
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Thu Sep 5 06:49:02 PDT 2019
Uhm, might be a problem if you have thousands of layers on GeoServer. We
need to be careful hitting the catalog reload everytime.
Do you have the chance to try a reload with a huge GeoServer catalog?
Il giorno gio 5 set 2019 alle ore 15:45 Paolo Corti <pcorti at gmail.com> ha
scritto:
> Hi Alessio
> reloading the catalog seems to have fixed it. Maybe we should reload
> the catalog after a layer remove? (I thought it is already the case)
> thanks
> Paolo
> On Thu, Sep 5, 2019 at 9:35 AM Alessio Fabiani
> <alessio.fabiani at geo-solutions.it> wrote:
> > It looks something related to GeoServer catalog.
> > Could you try if just reloading it, instead of restarting GeoServer,
> also works?
> > Il giorno gio 5 set 2019 alle ore 15:31 Paolo Corti <pcorti at gmail.com>
> ha scritto:
> >> Dear Alessio
> >> unfortunately this doesn't appear to be helpful. My idea is that there
> >> is something wrong in authorization from GeoFence.
> >> Here is what happening:
> >> * Restart GeoServer
> >> * First layer upload works correctly
> >> * I then remove the layer and I upload it again
> >> * I get the error. Checkin in GeoServer log I see:
> >> 2019-09-05 13:25:39,175 ERROR [geoserver.rest] - No such datastore:
> >> geonode,rivers
> >> org.geoserver.rest.ResourceNotFoundException 404 NOT_FOUND: No such
> >> datastore: geonode,rivers
> >> Restarting GeoServer will fix this.
> >> This is happening in a GeoNode project, let me see if I can experience
> >> the same locally.
> >> ps: I have seen your PR with the changes in gsconfig, I believe anyway
> >> that they are useful, will merge it as soon as build is finalized.
> >> thanks for helping with this
> >> Paolo
> >> On Thu, Sep 5, 2019 at 8:56 AM Alessio Fabiani
> >> > @Paolo any chanche to test the update of the library
> >> > (maybe be sure you first removed completely the old one, gsconfig)
> >> > pip install geoserver-restconfig==1.0.3
> >> > Il giorno mer 4 set 2019 alle ore 23:11 Paolo Corti <pcorti at gmail.com>
> ha scritto:
> >> >> Looking in the GeoServer log, it appears that GeoNode upload fails to
> >> >> create the style (and then the layer) in step 7 because it cannot
> find
> >> >> the newly created GeoServer layer (even if this was already created
> at
> >> >> step 4 in the upload process). This is the error I see in GeoServer:
> >> >> 2019-09-04 21:05:42,632 ERROR [geoserver.rest] - No such layer:
> geonode:rivers
> >> >> layer: geonode:rivers
> >> >> That looks like a regression? Or some configuration which is not
> correct?
> >> >> In my case I am using DELAYED_SECURITY_SIGNAL set to True.
> >> >> thanks
> >> >> Paolo
> >> >> On Wed, Sep 4, 2019 at 5:01 PM Paolo Corti <pcorti at gmail.com> wrote:
> >> >> > Hi devs
> >> >> > I am experiencing the following issue on an instance using GeoNode
> >> >> > master from a GeoNode project and PostGIS as a datastore. When
> >> >> > uploading a layer, I see the following
> >> >> > error message:
> >> >> > >>> Step 7. Creating style for [rivers]
> >> >> > Traceback (most recent call last):
> >> >> > File "/home/ubuntu/geonode/geonode/geoserver/helpers.py", line
> 246,
> >> >> > in get_sld_for
> >> >> > _default_style = layer.default_style
> >> >> > AttributeError: 'FeatureType' object has no attribute
> 'default_style'
> 255,
> >> >> > in get_sld_for
> >> >> > name = gs_layer.default_style.name if gs_layer.default_style
> is
> >> >> > not None else "raster"
> >> >> > AttributeError: 'NoneType' object has no attribute 'default_style'
> >> >> > after that, the layer is created in Django but not in GeoServer.
> Any
> >> >> > hint why this could be happening before I debug it on my own?
> >> >> > I noticed that after restarting GeoServer the layer is again
> uploaded correctly.
> >> >> > Paolo
> >> >> > Paolo Corti
> >> >> > Geospatial software developer
> >> >> > web: http://www.paolocorti.net
> >> >> > twitter: @capooti
> >> >> > skype: capooti
> >> >> > #drt3jc1
> >> >> Paolo Corti
> >> >> twitter: @capooti
> >> >> skype: capooti
> >> >> #drt3jc1
> >> >> _______________________________________________
> >> >> geonode-devel mailing list
> >> >> geonode-devel at lists.osgeo.org
> >> >> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> >> > GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> >> > Ing. Alessio Fabiani
> >> > @alfa7691
> >> > Founder/Technical Lead
> >> > GeoSolutions S.A.S.
> >> > Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> >> > phone: +39 0584 962313
> >> > fax: +39 0584 1660272
> >> > mob: +39 331 6233686
> >> > http://www.geo-solutions.it
> >> > http://twitter.com/geosolutions_it
> >> > Con riferimento alla normativa sul trattamento dei dati personali
> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
> si precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> >> > This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
> >> Paolo Corti
> >> twitter: @capooti
> >> skype: capooti
> >> #drt3jc1
> > @alfa7691
> > GeoSolutions S.A.S.
> > Con riferimento alla normativa sul trattamento dei dati personali (Reg.
> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> Paolo Corti
> twitter: @capooti
> skype: capooti
> #drt3jc1
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190905/97e74d94/attachment-0001.html>
More information about the geonode-devel
