[GeoNode-devel] errors with style creation during layer upload to PostGIS
Alessio Fabiani alessio.fabiani at geo-solutions.it
Thu Sep 5 06:54:54 PDT 2019
Also, maybe just try a reset instead of a reload.
Moreover, is this problem related to raster data too?
Il giorno gio 5 set 2019 alle ore 15:49 Alessio Fabiani <
alessio.fabiani at geo-solutions.it> ha scritto:
> Uhm, might be a problem if you have thousands of layers on GeoServer. We
> need to be careful hitting the catalog reload everytime.
> Do you have the chance to try a reload with a huge GeoServer catalog?
> Il giorno gio 5 set 2019 alle ore 15:45 Paolo Corti <pcorti at gmail.com> ha
> scritto:
>> Hi Alessio
>> reloading the catalog seems to have fixed it. Maybe we should reload
>> the catalog after a layer remove? (I thought it is already the case)
>> thanks
>> Paolo
>> On Thu, Sep 5, 2019 at 9:35 AM Alessio Fabiani
>> <alessio.fabiani at geo-solutions.it> wrote:
>> > It looks something related to GeoServer catalog.
>> > Could you try if just reloading it, instead of restarting GeoServer,
>> also works?
>> > Il giorno gio 5 set 2019 alle ore 15:31 Paolo Corti <pcorti at gmail.com>
>> ha scritto:
>> >> Dear Alessio
>> >> unfortunately this doesn't appear to be helpful. My idea is that there
>> >> is something wrong in authorization from GeoFence.
>> >> Here is what happening:
>> >> * Restart GeoServer
>> >> * First layer upload works correctly
>> >> * I then remove the layer and I upload it again
>> >> * I get the error. Checkin in GeoServer log I see:
>> >> 2019-09-05 13:25:39,175 ERROR [geoserver.rest] - No such datastore:
>> >> geonode,rivers
>> >> org.geoserver.rest.ResourceNotFoundException 404 NOT_FOUND: No such
>> >> datastore: geonode,rivers
>> >> Restarting GeoServer will fix this.
>> >> This is happening in a GeoNode project, let me see if I can experience
>> >> the same locally.
>> >> ps: I have seen your PR with the changes in gsconfig, I believe anyway
>> >> that they are useful, will merge it as soon as build is finalized.
>> >> thanks for helping with this
>> >> Paolo
>> >> On Thu, Sep 5, 2019 at 8:56 AM Alessio Fabiani
>> >> > @Paolo any chanche to test the update of the library
>> >> > (maybe be sure you first removed completely the old one, gsconfig)
>> >> > pip install geoserver-restconfig==1.0.3
>> >> > Il giorno mer 4 set 2019 alle ore 23:11 Paolo Corti <
>> pcorti at gmail.com> ha scritto:
>> >> >> Looking in the GeoServer log, it appears that GeoNode upload fails
>> to
>> >> >> create the style (and then the layer) in step 7 because it cannot
>> find
>> >> >> the newly created GeoServer layer (even if this was already created
>> at
>> >> >> step 4 in the upload process). This is the error I see in GeoServer:
>> >> >> 2019-09-04 21:05:42,632 ERROR [geoserver.rest] - No such layer:
>> geonode:rivers
>> >> >> layer: geonode:rivers
>> >> >> That looks like a regression? Or some configuration which is not
>> correct?
>> >> >> In my case I am using DELAYED_SECURITY_SIGNAL set to True.
>> >> >> thanks
>> >> >> Paolo
>> >> >> On Wed, Sep 4, 2019 at 5:01 PM Paolo Corti <pcorti at gmail.com>
>> wrote:
>> >> >> > Hi devs
>> >> >> > I am experiencing the following issue on an instance using GeoNode
>> >> >> > master from a GeoNode project and PostGIS as a datastore. When
>> >> >> > uploading a layer, I see the following
>> >> >> > error message:
>> >> >> > >>> Step 7. Creating style for [rivers]
>> >> >> > Traceback (most recent call last):
>> >> >> >   File "/home/ubuntu/geonode/geonode/geoserver/helpers.py", line
>> 246,
>> >> >> > in get_sld_for
>> >> >> >     _default_style = layer.default_style
>> >> >> > AttributeError: 'FeatureType' object has no attribute
>> 'default_style'
>> 255,
>> >> >> > in get_sld_for
>> >> >> >     name = gs_layer.default_style.name if gs_layer.default_style
>> is
>> >> >> > not None else "raster"
>> >> >> > AttributeError: 'NoneType' object has no attribute 'default_style'
>> >> >> > after that, the layer is created in Django but not in GeoServer.
>> Any
>> >> >> > hint why this could be happening before I debug it on my own?
>> >> >> > I noticed that after restarting GeoServer the layer is again
>> uploaded correctly.
>> >> >> > Paolo
>> >> >> > Paolo Corti
>> >> >> > Geospatial software developer
>> >> >> > web: http://www.paolocorti.net
>> >> >> > twitter: @capooti
>> >> >> > skype: capooti
>> >> >> > #drt3jc1
>> >> >> Paolo Corti
>> >> >> twitter: @capooti
>> >> >> skype: capooti
>> >> >> #drt3jc1
>> >> >> _______________________________________________
>> >> >> geonode-devel mailing list
>> >> >> geonode-devel at lists.osgeo.org
>> >> >> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>> >> > GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> >> > Ing. Alessio Fabiani
>> >> > @alfa7691
>> >> > Founder/Technical Lead
>> >> > GeoSolutions S.A.S.
>> >> > Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>> >> > phone: +39 0584 962313
>> >> > fax:     +39 0584 1660272
>> >> > mob:   +39 331 6233686
>> >> > http://www.geo-solutions.it
>> >> > http://twitter.com/geosolutions_it
>> >> > Con riferimento alla normativa sul trattamento dei dati personali
>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>> si precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> >> > This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
>> >> Paolo Corti
>> >> twitter: @capooti
>> >> skype: capooti
>> >> #drt3jc1
>> > @alfa7691
>> > GeoSolutions S.A.S.
>> > Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> Paolo Corti
>> twitter: @capooti
>> skype: capooti
>> #drt3jc1
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190905/6d94f925/attachment-0001.html>
More information about the geonode-devel mailing list
