[GeoNode-devel] Add the region of the resource in the search field area
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Tue Sep 17 00:35:49 PDT 2019
Dear Samuel,
thanks for your contribution.
I guess the best way to start working on this stuff would be to:
1. Open an issue on GitHub describing as much as possible the new feature
you want to achieve and the use case
2. Start working on a branch a create a DRAFT Pull Request
Developers will provide help by either commenting your code and jumping
into the branch actively.
Regards,
Alessio.
Il giorno mar 17 set 2019 alle ore 09:16 Samuel POTTER <
samuel.potter at cirad.fr> ha scritto:
> Good morning,
> One of my task is to add the region of the resource when someone is
> looking for one of them. It will allow the user to choose the good one
> because different ressources can have the same name but coming from
> different regions. At the moment the search field only display the the name
> of the resource for example "Sugarcane area" but my final goal is to have
> something like "Sugarcane area Thailande" and "Sugarcane area Reunion"
> which will allow the user to differentiate them for example. If someone
> could help me I will be glad.
> Thank you,
> POTTER Samuel
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190917/b51a2921/attachment-0001.html>
More information about the geonode-devel
