[GeoNode-devel] error during layer upload with master
Paolo Corti
pcorti at gmail.com
Tue Sep 24 13:18:16 PDT 2019
Hi Alessio
in my case the process is failing because layer.store is empty when we
run gs_catalog.get_resource at geoserver.signals [1]. This cause
gs_resource to be None.
I am using a PostGIS datastore as the backend. This was working
properly a few commits ago.
Hope this helps to diagnose the issue
cheers
Paolo
[1] https://github.com/GeoNode/geonode/blob/master/geonode/geoserver/signals.py#L144
On Tue, Sep 24, 2019 at 11:22 AM Alessio Fabiani
<alessio.fabiani at geo-solutions.it> wrote:
> Any hint on how to reproduce this?
> Do you have a special configuration / deployment?
> Il giorno mar 24 set 2019 alle ore 17:08 Paolo Corti <pcorti at gmail.com> ha scritto:
>> This is what I currently see if I upload a layer:
>> >>> Step 10. Creating Django record for [public_violence_1ja_2]
>> There isn't a geoserver resource for this layer: public_violence_1ja_2
>> Traceback (most recent call last):
>> File "/home/ubuntu/wm-2.10.x/env/local/lib/python2.7/site-packages/kombu/utils/scheduling.py",
>> line 56, in get
>> return self.fun(resource, callback, **kwargs)
>> File "/home/ubuntu/wm-2.10.x/env/local/lib/python2.7/site-packages/kombu/transport/virtual/base.py",
>> line 405, in _get_and_deliver
>> message = self._get(queue)
>> File "/home/ubuntu/wm-2.10.x/env/local/lib/python2.7/site-packages/kombu/transport/memory.py",
>> line 27, in _get
>> return self._queue_for(queue).get(block=False)
>> File "/usr/lib/python2.7/Queue.py", line 165, in get
>> raise Empty
>> Empty
>> The layer is anyway created in GeoNode and GeoServer, but is not
>> rendered in layer preview and initial extent is wrong. Should I file a
>> ticket?
>> thanks
>> Paolo
>> Paolo Corti
>> Geospatial software developer
>> web: http://www.paolocorti.net
>> twitter: @capooti
>> skype: capooti
>> #drt3jc1
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Paolo Corti
twitter: @capooti
skype: capooti
#drt3jc1
More information about the geonode-devel
