[GeoNode-devel] error during layer upload with master
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Sep 25 01:04:25 PDT 2019
That's weird, I cannot reproduce this issue currently by using master
branch.
Can you maybe send me a snapshot of your local_settings / environment?
Are you using the UPLOADER REST or IMPORTER method?
Maybe check that you have the latest geoserver-restconfig lib. Try to
uninstall it, and completely cleanup site-packages, and reinstall the
latest.
Il giorno mar 24 set 2019 alle ore 22:18 Paolo Corti <pcorti at gmail.com> ha
scritto:
> Hi Alessio
> in my case the process is failing because layer.store is empty when we
> run gs_catalog.get_resource at geoserver.signals [1]. This cause
> gs_resource to be None.
> I am using a PostGIS datastore as the backend. This was working
> properly a few commits ago.
> Hope this helps to diagnose the issue
> cheers
> Paolo
> [1]
> https://github.com/GeoNode/geonode/blob/master/geonode/geoserver/signals.py#L144
> On Tue, Sep 24, 2019 at 11:22 AM Alessio Fabiani
> <alessio.fabiani at geo-solutions.it> wrote:
> > Any hint on how to reproduce this?
> > Do you have a special configuration / deployment?
> > Il giorno mar 24 set 2019 alle ore 17:08 Paolo Corti <pcorti at gmail.com>
> ha scritto:
> >> This is what I currently see if I upload a layer:
> >> >>> Step 10. Creating Django record for [public_violence_1ja_2]
> >> There isn't a geoserver resource for this layer: public_violence_1ja_2
> >> Traceback (most recent call last):
> >>   File
> "/home/ubuntu/wm-2.10.x/env/local/lib/python2.7/site-packages/kombu/utils/scheduling.py",
> >> line 56, in get
> >>     return self.fun(resource, callback, **kwargs)
> >>   File
> "/home/ubuntu/wm-2.10.x/env/local/lib/python2.7/site-packages/kombu/transport/virtual/base.py",
> >> line 405, in _get_and_deliver
> >>     message = self._get(queue)
> >>   File
> "/home/ubuntu/wm-2.10.x/env/local/lib/python2.7/site-packages/kombu/transport/memory.py",
> >> line 27, in _get
> >>     return self._queue_for(queue).get(block=False)
> >>   File "/usr/lib/python2.7/Queue.py", line 165, in get
> >>     raise Empty
> >> Empty
> >> The layer is anyway created in GeoNode and GeoServer, but is not
> >> rendered in layer preview and initial extent is wrong. Should I file a
> >> ticket?
> >> thanks
> >> Paolo
> >> Paolo Corti
> >> Geospatial software developer
> >> web: http://www.paolocorti.net
> >> twitter: @capooti
> >> skype: capooti
> >> #drt3jc1
> >> _______________________________________________
> >> geonode-devel mailing list
> >> geonode-devel at lists.osgeo.org
> >> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> > GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> > Ing. Alessio Fabiani
> > @alfa7691
> > Founder/Technical Lead
> > GeoSolutions S.A.S.
> > Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> > phone: +39 0584 962313
> > fax:     +39 0584 1660272
> > mob:   +39 331 6233686
> > http://www.geo-solutions.it
> > http://twitter.com/geosolutions_it
> > Con riferimento alla normativa sul trattamento dei dati personali (Reg.
> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> > This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
> Paolo Corti
> twitter: @capooti
> skype: capooti
> #drt3jc1
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190925/aeb21436/attachment.html>
More information about the geonode-devel mailing list
