[GeoNode-devel] error during layer upload with master
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Fri Sep 27 08:37:10 PDT 2019
@Paolo Corti <pcorti at gmail.com> it looks like this is caused by a timing
issue on signals.
I found a possible solution by waiting for the layer on GeoServer catalog
to be fully configured.
This might also solve the https://github.com/GeoNode/geonode/issues/4827
problem.
Tentative fix here https://github.com/GeoNode/geonode/pull/4960
Il giorno mer 25 set 2019 alle ore 10:04 Alessio Fabiani <
alessio.fabiani at geo-solutions.it> ha scritto:
> That's weird, I cannot reproduce this issue currently by using master
> branch.
> Can you maybe send me a snapshot of your local_settings / environment?
> Are you using the UPLOADER REST or IMPORTER method?
> Maybe check that you have the latest geoserver-restconfig lib. Try to
> uninstall it, and completely cleanup site-packages, and reinstall the
> latest.
> Il giorno mar 24 set 2019 alle ore 22:18 Paolo Corti <pcorti at gmail.com>
> ha scritto:
>> Hi Alessio
>> in my case the process is failing because layer.store is empty when we
>> run gs_catalog.get_resource at geoserver.signals [1]. This cause
>> gs_resource to be None.
>> I am using a PostGIS datastore as the backend. This was working
>> properly a few commits ago.
>> Hope this helps to diagnose the issue
>> cheers
>> Paolo
>> [1]
>> https://github.com/GeoNode/geonode/blob/master/geonode/geoserver/signals.py#L144
>> On Tue, Sep 24, 2019 at 11:22 AM Alessio Fabiani
>> <alessio.fabiani at geo-solutions.it> wrote:
>> > Any hint on how to reproduce this?
>> > Do you have a special configuration / deployment?
>> > Il giorno mar 24 set 2019 alle ore 17:08 Paolo Corti <pcorti at gmail.com>
>> ha scritto:
>> >> This is what I currently see if I upload a layer:
>> >> >>> Step 10. Creating Django record for [public_violence_1ja_2]
>> >> There isn't a geoserver resource for this layer: public_violence_1ja_2
>> >> Traceback (most recent call last):
>> >> File
>> "/home/ubuntu/wm-2.10.x/env/local/lib/python2.7/site-packages/kombu/utils/scheduling.py",
>> >> line 56, in get
>> >> return self.fun(resource, callback, **kwargs)
>> >> File
>> "/home/ubuntu/wm-2.10.x/env/local/lib/python2.7/site-packages/kombu/transport/virtual/base.py",
>> >> line 405, in _get_and_deliver
>> >> message = self._get(queue)
>> >> File
>> "/home/ubuntu/wm-2.10.x/env/local/lib/python2.7/site-packages/kombu/transport/memory.py",
>> >> line 27, in _get
>> >> return self._queue_for(queue).get(block=False)
>> >> File "/usr/lib/python2.7/Queue.py", line 165, in get
>> >> raise Empty
>> >> Empty
>> >> The layer is anyway created in GeoNode and GeoServer, but is not
>> >> rendered in layer preview and initial extent is wrong. Should I file a
>> >> ticket?
>> >> thanks
>> >> Paolo
>> >> Paolo Corti
>> >> Geospatial software developer
>> >> web: http://www.paolocorti.net
>> >> twitter: @capooti
>> >> skype: capooti
>> >> #drt3jc1
>> >> _______________________________________________
>> >> geonode-devel mailing list
>> >> geonode-devel at lists.osgeo.org
>> >> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>> > GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> > Ing. Alessio Fabiani
>> > @alfa7691
>> > Founder/Technical Lead
>> > GeoSolutions S.A.S.
>> > Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>> > phone: +39 0584 962313
>> > fax: +39 0584 1660272
>> > mob: +39 331 6233686
>> > http://www.geo-solutions.it
>> > http://twitter.com/geosolutions_it
>> > Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> > This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
>> Paolo Corti
>> twitter: @capooti
>> skype: capooti
>> #drt3jc1
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190927/6b8301a0/attachment-0001.html>
More information about the geonode-devel
