[GeoNode-devel] error during layer upload with master
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Sep 30 03:52:19 PDT 2019
@Paolo Corti <pcorti at gmail.com> PR Updated. Please take a look
https://github.com/GeoNode/geonode/pull/4960
thanks,
-A.
Il giorno ven 27 set 2019 alle ore 22:15 Paolo Corti <pcorti at gmail.com> ha
scritto:
> Hey Alessio
> yes, this is the same road I was thinking of. Note that the CI fails
> right now (GeoServer integration tests).
> In any case I'd suggest to have the _max_tries variable configurable
> (maybe in settings.UPLOADER['OPTIONS']). Right now its value (100) is
> too much as the process would hang 100 seconds if something weird
> happens.
> Thanks a lot for helping with this :)
> Paolo
> On Fri, Sep 27, 2019 at 11:37 AM Alessio Fabiani
> <alessio.fabiani at geo-solutions.it> wrote:
> > @Paolo Corti it looks like this is caused by a timing issue on signals.
> > I found a possible solution by waiting for the layer on GeoServer
> catalog to be fully configured.
> > This might also solve the https://github.com/GeoNode/geonode/issues/4827
> problem.
> > Tentative fix here https://github.com/GeoNode/geonode/pull/4960
> > Il giorno mer 25 set 2019 alle ore 10:04 Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> ha scritto:
> >> That's weird, I cannot reproduce this issue currently by using master
> branch.
> >> Can you maybe send me a snapshot of your local_settings / environment?
> >> Are you using the UPLOADER REST or IMPORTER method?
> >> Maybe check that you have the latest geoserver-restconfig lib. Try to
> uninstall it, and completely cleanup site-packages, and reinstall the
> latest.
> >> Il giorno mar 24 set 2019 alle ore 22:18 Paolo Corti <pcorti at gmail.com>
> ha scritto:
> >>> Hi Alessio
> >>> in my case the process is failing because layer.store is empty when we
> >>> run gs_catalog.get_resource at geoserver.signals [1]. This cause
> >>> gs_resource to be None.
> >>> I am using a PostGIS datastore as the backend. This was working
> >>> properly a few commits ago.
> >>> Hope this helps to diagnose the issue
> >>> cheers
> >>> Paolo
> >>> [1]
> https://github.com/GeoNode/geonode/blob/master/geonode/geoserver/signals.py#L144
> >>> On Tue, Sep 24, 2019 at 11:22 AM Alessio Fabiani
> >>> > Any hint on how to reproduce this?
> >>> > Do you have a special configuration / deployment?
> >>> > Il giorno mar 24 set 2019 alle ore 17:08 Paolo Corti <
> pcorti at gmail.com> ha scritto:
> >>> >> This is what I currently see if I upload a layer:
> >>> >> >>> Step 10. Creating Django record for [public_violence_1ja_2]
> >>> >> There isn't a geoserver resource for this layer:
> >>> >> Traceback (most recent call last):
> >>> >>   File
> "/home/ubuntu/wm-2.10.x/env/local/lib/python2.7/site-packages/kombu/utils/scheduling.py",
> >>> >> line 56, in get
> >>> >>     return self.fun(resource, callback, **kwargs)
> >>> >>   File
> "/home/ubuntu/wm-2.10.x/env/local/lib/python2.7/site-packages/kombu/transport/virtual/base.py",
> >>> >> line 405, in _get_and_deliver
> >>> >>     message = self._get(queue)
> >>> >>   File
> "/home/ubuntu/wm-2.10.x/env/local/lib/python2.7/site-packages/kombu/transport/memory.py",
> >>> >> line 27, in _get
> >>> >>     return self._queue_for(queue).get(block=False)
> >>> >>   File "/usr/lib/python2.7/Queue.py", line 165, in get
> >>> >>     raise Empty
> >>> >> Empty
> >>> >> The layer is anyway created in GeoNode and GeoServer, but is not
> >>> >> rendered in layer preview and initial extent is wrong. Should I
> file a
> >>> >> ticket?
> >>> >> thanks
> >>> >> Paolo
> >>> >> Paolo Corti
> >>> >> Geospatial software developer
> >>> >> web: http://www.paolocorti.net
> >>> >> twitter: @capooti
> >>> >> skype: capooti
> >>> >> #drt3jc1
> >>> >> _______________________________________________
> >>> >> geonode-devel mailing list
> >>> >> geonode-devel at lists.osgeo.org
> >>> >> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> >>> > GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> >>> > Ing. Alessio Fabiani
> >>> > @alfa7691
> >>> > Founder/Technical Lead
> >>> > GeoSolutions S.A.S.
> >>> > Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> >>> > phone: +39 0584 962313
> >>> > fax:     +39 0584 1660272
> >>> > mob:   +39 331 6233686
> >>> > http://www.geo-solutions.it
> >>> > http://twitter.com/geosolutions_it
> >>> > Con riferimento alla normativa sul trattamento dei dati personali
> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
> si precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> >>> > This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
> >>> Paolo Corti
> >>> twitter: @capooti
> >>> skype: capooti
> >>> #drt3jc1
> >> @alfa7691
> >> GeoSolutions S.A.S.
> >> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> > @alfa7691
> > GeoSolutions S.A.S.
> Paolo Corti
> twitter: @capooti
> skype: capooti
> #drt3jc1
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20190930/f1622dbc/attachment-0001.html>
More information about the geonode-devel mailing list
