[GeoNode-devel] GeoNode 2.10.2 - starting the release process
Alessio Fabiani alessio.fabiani at geo-solutions.it
Mon Feb 10 08:46:33 PST 2020
Dear all, the 2.10.2 is almost ready (see
https://github.com/GeoNode/geonode/projects/3 ) are you aware of any
blocker/major issue that might prevent to finalize the release process?
I also created the usual spreadsheet for the Tests (here
http://bit.ly/38huuW2 ); the instance http://master.demo.geonode.org/ is
aligned with the latest 2.10.x updates if you want to use that one.
Also, if you want "admin" privileges on that instance to run the tests,
please write to me in private by specifying your master.demo username.
Regards,
Alessio.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20200210/1cd96677/attachment.html>
More information about the geonode-devel mailing list
