[GeoNode-devel] GeoNode 2.10.2 - starting the release process
Florian Hoedt florian.hoedt at thuenen.de
Wed Feb 12 00:27:15 PST 2020
Hello List,
Some information about the current progress for 2.10.2 testing:
TOT 		167
DONE 		124
IN PROGRESS 		1
TODO 		41
BLOCKED 		1
WONTDO 		0
TOT 		167
PASSED 	100 	116
TO INVESTIGATE 	0 	44
FAILED 	6 	7
Only 44 more checks need to be performed, some of them are tests which lead to inconclusive results. From the open ones 17 are related to Risk Management Tools which could not be tested on master.demo.geonode.org. @ Alessio I will mark them as WONTDO?
We are close.
MSc Florian Hoedt
Coordinator Geoinformatics | OpenData Representative
Thünen Institute, Centre for Information Management
Bundesallee 44
38116 Braunschweig
Tel: +49 531 596-1428
Fax: +49 531 596-1499
Mail: florian.hoedt at thuenen.de
Web: www.thuenen.de
The Johann Heinrich von Thünen Institute, Federal Research Institute for Rural Areas, Forestry and Fisheries – Thünen Institute in brief – consists of 14 specialized institutes that carry out research and provide policy advice in the fields of economy, ecology and technology.
Von: "Alessio Fabiani" <alessio.fabiani at geo-solutions.it>
An: "geonode-devel" <geonode-devel at lists.osgeo.org>
Gesendet: Montag, 10. Februar 2020 17:46:33
Betreff: [GeoNode-devel] GeoNode 2.10.2 - starting the release process
Dear all, the 2.10.2 is almost ready (see [ https://github.com/GeoNode/geonode/projects/3 | https://github.com/GeoNode/geonode/projects/3 ] ) are you aware of any blocker/major issue that might prevent to finalize the release process?
I also created the usual spreadsheet for the Tests (here [ http://bit.ly/38huuW2 | http://bit.ly/38huuW2 ] ); the instance [ http://master.demo.geonode.org/ | http://master.demo.geonode.org/ ] is aligned with the latest 2.10.x updates if you want to use that one.
Also, if you want "admin" privileges on that instance to run the tests, please write to me in private by specifying your master.demo username.
Regards,
Alessio.
GeoServer Professional Services from the experts! Visit [ http://goo.gl/it488V | http://goo.gl/it488V ] for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
[ http://www.geo-solutions.it/ | http://www.geo-solutions.it ]
[ http://twitter.com/geosolutions_it | http://twitter.com/geosolutions_it ]
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
geonode-devel mailing list
https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20200212/5c27afae/attachment-0001.html>
More information about the geonode-devel mailing list
