[GeoNode-devel] GeoNode 2.10.2 - starting the release process
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Feb 12 00:31:12 PST 2020
@Florian Hoedt <florian.hoedt at thuenen.de> let's remove the rows that do not
apply to the release and/or add some that have not considered into the list.
Feel free to modify the spreadsheet. I will take a look later today.
Thanks Florian,
-A.
Il giorno mer 12 feb 2020 alle ore 09:27 Florian Hoedt <
florian.hoedt at thuenen.de> ha scritto:
> Hello List,
> Some information about the current progress for 2.10.2 testing:
> TOT 167
> DONE 124
> IN PROGRESS 1
> TODO 41
> BLOCKED 1
> WONTDO 0
> TOT 167
> PASSED 100 116
> TO INVESTIGATE 0 44
> FAILED 6 7
> Only 44 more checks need to be performed, some of them are tests which
> lead to inconclusive results. From the open ones 17 are related to Risk
> Management Tools which could not be tested on master.demo.geonode.org. @
> Alessio I will mark them as WONTDO?
> We are close.
> MSc Florian Hoedt
> Coordinator Geoinformatics | OpenData Representative
> Thünen Institute, Centre for Information Management
> Bundesallee 44
> 38116 Braunschweig
> Tel:  +49 531 596-1428
> Fax:  +49 531 596-1499
> Mail: florian.hoedt at thuenen.de
> Web:  www.thuenen.de
> The Johann Heinrich von Thünen Institute, Federal Research Institute for
> Rural Areas, Forestry and Fisheries – Thünen Institute in brief – consists
> of 14 specialized institutes that carry out research and provide policy
> advice in the fields of economy, ecology and technology.
> *Von: *"Alessio Fabiani" <alessio.fabiani at geo-solutions.it>
> *An: *"geonode-devel" <geonode-devel at lists.osgeo.org>
> *Gesendet: *Montag, 10. Februar 2020 17:46:33
> *Betreff: *[GeoNode-devel] GeoNode 2.10.2 - starting the release process
> Dear all, the 2.10.2 is almost ready (see
> https://github.com/GeoNode/geonode/projects/3 ) are you aware of any
> blocker/major issue that might prevent to finalize the release process?
> I also created the usual spreadsheet for the Tests (here
> http://bit.ly/38huuW2 ); the instance http://master.demo.geonode.org/ is
> aligned with the latest 2.10.x updates if you want to use that one.
> Also, if you want "admin" privileges on that instance to run the tests,
> please write to me in private by specifying your master.demo username.
> Regards,
> Alessio.
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
> geonode-devel mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20200212/fdd3a7a5/attachment-0001.html>
More information about the geonode-devel mailing list
