[GeoNode-devel] GeoNode 2.10.2 - starting the release process
Florian Hoedt
florian.hoedt at thuenen.de
Wed Feb 12 01:51:40 PST 2020
Were done. I deleted the Risk Management Tools and started to fix (up to row 46) the SLD XML text which is in parts of the Description column (F).
TOT 150
DONE 148
IN PROGRESS 0
TODO 1
BLOCKED 1
WONTDO 0
The TODO is related to a superuser check I can not perform. The Blocked one is related to group tests - which seem to be broken currently because of a test I have done before (https://docs.google.com/spreadsheets/d/1j_OBEHUr5fXr9HAXhqgNIGBqa9bPikAkgeNBk6ui2Fo/edit#gid=376642658&range=P35 ).
Regarding adding anything to the tests sheet: MapStore2 integration is not completly tested in there. I am not sure if we need this, since mapstore itself will get tested? Things we maybe should cover:
Are widgets properly saved
Are filters properly saved
Are layer / group/ map settings properly saved (see eg. https://github.com/GeoNode/geonode/issues/5091)
I have to switch to other tasks now.
yours,
Florian
MSc Florian Hoedt
Coordinator Geoinformatics | OpenData Representative
Thünen Institute, Centre for Information Management
Bundesallee 44
38116 Braunschweig
Tel: +49 531 596-1428
Fax: +49 531 596-1499
Mail: florian.hoedt at thuenen.de
Web: www.thuenen.de
The Johann Heinrich von Thünen Institute, Federal Research Institute for Rural Areas, Forestry and Fisheries – Thünen Institute in brief – consists of 14 specialized institutes that carry out research and provide policy advice in the fields of economy, ecology and technology.
Von: "Alessio Fabiani" <alessio.fabiani at geo-solutions.it>
An: "Florian Hoedt" <florian.hoedt at thuenen.de>
CC: "Alessio Fabiani" <alessio.fabiani at geo-solutions.it>, "geonode-devel" <geonode-devel at lists.osgeo.org>
Gesendet: Mittwoch, 12. Februar 2020 09:31:12
Betreff: Re: [GeoNode-devel] GeoNode 2.10.2 - starting the release process
[ mailto:florian.hoedt at thuenen.de | @Florian Hoedt ] let's remove the rows that do not apply to the release and/or add some that have not considered into the list.
Feel free to modify the spreadsheet. I will take a look later today.
Thanks Florian,
-A.
Il giorno mer 12 feb 2020 alle ore 09:27 Florian Hoedt < [ mailto:florian.hoedt at thuenen.de | florian.hoedt at thuenen.de ] > ha scritto:
Hello List,
Some information about the current progress for 2.10.2 testing:
TOT 167
DONE 124
IN PROGRESS 1
TODO 41
BLOCKED 1
WONTDO 0
TOT 167
PASSED 100 116
TO INVESTIGATE 0 44
FAILED 6 7
Only 44 more checks need to be performed, some of them are tests which lead to inconclusive results. From the open ones 17 are related to Risk Management Tools which could not be tested on [ http://master.demo.geonode.org/ | master.demo.geonode.org ] . @ Alessio I will mark them as WONTDO?
We are close.
MSc Florian Hoedt
Bundesallee 44
38116 Braunschweig
Mail: [ mailto:florian.hoedt at thuenen.de | florian.hoedt at thuenen.de ]
Web: [ http://www.thuenen.de/ | www.thuenen.de ]
Von: "Alessio Fabiani" < [ mailto:alessio.fabiani at geo-solutions.it | alessio.fabiani at geo-solutions.it ] >
An: "geonode-devel" < [ mailto:geonode-devel at lists.osgeo.org | geonode-devel at lists.osgeo.org ] >
Gesendet: Montag, 10. Februar 2020 17:46:33
Betreff: [GeoNode-devel] GeoNode 2.10.2 - starting the release process
Dear all, the 2.10.2 is almost ready (see [ https://github.com/GeoNode/geonode/projects/3 | https://github.com/GeoNode/geonode/projects/3 ] ) are you aware of any blocker/major issue that might prevent to finalize the release process?
I also created the usual spreadsheet for the Tests (here [ http://bit.ly/38huuW2 | http://bit.ly/38huuW2 ] ); the instance [ http://master.demo.geonode.org/ | http://master.demo.geonode.org/ ] is aligned with the latest 2.10.x updates if you want to use that one.
Also, if you want "admin" privileges on that instance to run the tests, please write to me in private by specifying your master.demo username.
Regards,
Alessio.
GeoServer Professional Services from the experts! Visit [ http://goo.gl/it488V | http://goo.gl/it488V ] for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
[ http://www.geo-solutions.it/ | http://www.geo-solutions.it ]
[ http://twitter.com/geosolutions_it | http://twitter.com/geosolutions_it ]
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
geonode-devel mailing list
[ https://lists.osgeo.org/mailman/listinfo/geonode-devel | https://lists.osgeo.org/mailman/listinfo/geonode-devel ]
@alfa7691
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20200212/302b5c88/attachment-0001.html>
More information about the geonode-devel
