[GeoNode-devel] GeoNode 2.10.2 - starting the release process
Alessio Fabiani alessio.fabiani at geo-solutions.it
Wed Feb 12 01:58:25 PST 2020
Thanks Florian,
yes, MapStore tests should be added too.
I will double check internally with Franco from GeoSolutions.
Thanks,
Alessio.
Il giorno mer 12 feb 2020 alle ore 10:51 Florian Hoedt <
florian.hoedt at thuenen.de> ha scritto:
> Hi,
> Were done. I deleted the Risk Management Tools and started to fix (up to
> row 46) the SLD XML text which is in parts of the Description column (F).
> TOT 150
> DONE 148
> IN PROGRESS 0
> TODO 1
> BLOCKED 1
> WONTDO 0
> The TODO is related to a superuser check I can not perform. The Blocked
> one is related to group tests - which seem to be broken currently because
> of a test I have done before (
> https://docs.google.com/spreadsheets/d/1j_OBEHUr5fXr9HAXhqgNIGBqa9bPikAkgeNBk6ui2Fo/edit#gid=376642658&range=P35
> Regarding adding anything to the tests sheet: MapStore2 integration is not
> completly tested in there. I am not sure if we need this, since mapstore
> itself will get tested? Things we maybe should cover:
> Are widgets properly saved
> Are filters properly saved
> Are layer / group/ map settings properly saved (see eg.
> https://github.com/GeoNode/geonode/issues/5091)
> I have to switch to other tasks now.
> yours,
> Florian
> MSc Florian Hoedt
> Coordinator Geoinformatics | OpenData Representative
> Thünen Institute, Centre for Information Management
> Bundesallee 44
> 38116 Braunschweig
> Tel:  +49 531 596-1428
> Fax:  +49 531 596-1499
> Mail: florian.hoedt at thuenen.de
> Web:  www.thuenen.de
> The Johann Heinrich von Thünen Institute, Federal Research Institute for
> Rural Areas, Forestry and Fisheries – Thünen Institute in brief – consists
> of 14 specialized institutes that carry out research and provide policy
> advice in the fields of economy, ecology and technology.
> *Von: *"Alessio Fabiani" <alessio.fabiani at geo-solutions.it>
> *An: *"Florian Hoedt" <florian.hoedt at thuenen.de>
> *CC: *"Alessio Fabiani" <alessio.fabiani at geo-solutions.it>,
> "geonode-devel" <geonode-devel at lists.osgeo.org>
> *Gesendet: *Mittwoch, 12. Februar 2020 09:31:12
> *Betreff: *Re: [GeoNode-devel] GeoNode 2.10.2 - starting the release
> process
> @Florian Hoedt <florian.hoedt at thuenen.de> let's remove the rows that do
> not apply to the release and/or add some that have not considered into the
> list.
> Feel free to modify the spreadsheet. I will take a look later today.
> Thanks Florian,
> -A.
> Il giorno mer 12 feb 2020 alle ore 09:27 Florian Hoedt <
>> Hello List,
>> Some information about the current progress for 2.10.2 testing:
>> TOT 167
>> DONE 124
>> IN PROGRESS 1
>> TODO 41
>> BLOCKED 1
>> WONTDO 0
>> TOT 167
>> PASSED 100 116
>> TO INVESTIGATE 0 44
>> FAILED 6 7
>> Only 44 more checks need to be performed, some of them are tests which
>> lead to inconclusive results. From the open ones 17 are related to Risk
>> Management Tools which could not be tested on master.demo.geonode.org. @
>> Alessio I will mark them as WONTDO?
>> We are close.
>> MSc Florian Hoedt
>> Bundesallee 44
>> 38116 Braunschweig
>> Web:  www.thuenen.de
>> *An: *"geonode-devel" <geonode-devel at lists.osgeo.org>
>> *Gesendet: *Montag, 10. Februar 2020 17:46:33
>> *Betreff: *[GeoNode-devel] GeoNode 2.10.2 - starting the release process
>> Dear all, the 2.10.2 is almost ready (see
>> https://github.com/GeoNode/geonode/projects/3 ) are you aware of any
>> blocker/major issue that might prevent to finalize the release process?
>> I also created the usual spreadsheet for the Tests (here
>> http://bit.ly/38huuW2 ); the instance http://master.demo.geonode.org/ is
>> aligned with the latest 2.10.x updates if you want to use that one.
>> Also, if you want "admin" privileges on that instance to run the tests,
>> please write to me in private by specifying your master.demo username.
>> Regards,
>> Alessio.
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
>> geonode-devel mailing list
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20200212/2018813d/attachment-0001.html>
More information about the geonode-devel mailing list
