[GeoNode-devel] Docker db4geonode continuous restart
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Feb 14 00:33:07 PST 2020
Hi Pieter,
try a "docker-compose logs -f --tail=30 db" in order to see the logs and
try to understand what's going on.
Il giorno gio 13 feb 2020 alle ore 19:20 Pieter du Plooy <
pjduplooy.gis at gmail.com> ha scritto:
> Hi guys.
> After a week or so away from geonode master, I did a complete rebuild
> after deleting all geonode related docker images.
> I have cloned the repo with the
> --config core.autocrlf=input --depth 1
> to run on Windows (as I did in the past).
> However the db4geonode image does not start (goes into continuous restart loop.
> Any help on this?
> Pieter
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20200214/fa9f78d9/attachment.html>
More information about the geonode-devel mailing list
