[GeoNode-devel] Docker db4geonode continuous restart
Pieter du Plooy
pjduplooy.gis at gmail.com
Fri Feb 14 01:32:14 PST 2020
Hi Alessio.
I get
db4geonode | 2020-02-14 09:29:53.638 UTC [1] FATAL: database files
are incompatible with server
db4geonode | 2020-02-14 09:29:53.638 UTC [1] DETAIL: The data
directory was initialized by PostgreSQL version 10, which is not compatible
with this version 11.2 (Debian 11.2-1.pgdg90+1).
Pieter
On Fri, Feb 14, 2020 at 10:33 AM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Hi Pieter,
> try a "docker-compose logs -f --tail=30 db" in order to see the logs and
> try to understand what's going on.
> Il giorno gio 13 feb 2020 alle ore 19:20 Pieter du Plooy <
> pjduplooy.gis at gmail.com> ha scritto:
>> Hi guys.
>> After a week or so away from geonode master, I did a complete rebuild
>> after deleting all geonode related docker images.
>> I have cloned the repo with the
>> --config core.autocrlf=input --depth 1
>> to run on Windows (as I did in the past).
>> However the db4geonode image does not start (goes into continuous restart loop.
>> Any help on this?
>> Pieter
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20200214/893dc123/attachment-0001.html>
More information about the geonode-devel
