[GeoNode-devel] Docker db4geonode continuous restart
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Feb 14 01:35:14 PST 2020
Ok, so, if you want to keep the old DB just downgrade to 10 the postgres
version on the Dockerfile and then run a "docker-compose up -d --build db"
again
Il giorno ven 14 feb 2020 alle ore 10:32 Pieter du Plooy <
pjduplooy.gis at gmail.com> ha scritto:
> Hi Alessio.
> I get
> db4geonode       | 2020-02-14 09:29:53.638 UTC [1] FATAL:  database files
> are incompatible with server
> db4geonode       | 2020-02-14 09:29:53.638 UTC [1] DETAIL:  The data
> directory was initialized by PostgreSQL version 10, which is not compatible
> with this version 11.2 (Debian 11.2-1.pgdg90+1).
> Pieter
> On Fri, Feb 14, 2020 at 10:33 AM Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Hi Pieter,
>> try a "docker-compose logs -f --tail=30 db" in order to see the logs and
>> try to understand what's going on.
>> Il giorno gio 13 feb 2020 alle ore 19:20 Pieter du Plooy <
>>> Hi guys.
>>> After a week or so away from geonode master, I did a complete rebuild
>>> after deleting all geonode related docker images.
>>> I have cloned the repo with the
>>> --config core.autocrlf=input --depth 1
>>> to run on Windows (as I did in the past).
>>> However the db4geonode image does not start (goes into continuous restart loop.
>>> Any help on this?
>>> Pieter
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20200214/72850199/attachment-0001.html>
More information about the geonode-devel mailing list
