[GeoNode-devel] Docker db4geonode continuous restart
Pieter du Plooy
pjduplooy.gis at gmail.com
Fri Feb 14 01:50:50 PST 2020
Hi Alessio
Can I delete all images and start from scratch?
Pieer
On Fri, Feb 14, 2020 at 11:35 AM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Ok, so, if you want to keep the old DB just downgrade to 10 the postgres
> version on the Dockerfile and then run a "docker-compose up -d --build db"
> again
> Il giorno ven 14 feb 2020 alle ore 10:32 Pieter du Plooy <
> pjduplooy.gis at gmail.com> ha scritto:
>> Hi Alessio.
>> I get
>> db4geonode | 2020-02-14 09:29:53.638 UTC [1] FATAL: database files
>> are incompatible with server
>> db4geonode | 2020-02-14 09:29:53.638 UTC [1] DETAIL: The data
>> directory was initialized by PostgreSQL version 10, which is not compatible
>> with this version 11.2 (Debian 11.2-1.pgdg90+1).
>> Pieter
>> On Fri, Feb 14, 2020 at 10:33 AM Alessio Fabiani <
>>> Hi Pieter,
>>> try a "docker-compose logs -f --tail=30 db" in order to see the logs and
>>> try to understand what's going on.
>>> Il giorno gio 13 feb 2020 alle ore 19:20 Pieter du Plooy <
>>>> Hi guys.
>>>> After a week or so away from geonode master, I did a complete rebuild
>>>> after deleting all geonode related docker images.
>>>> I have cloned the repo with the
>>>> --config core.autocrlf=input --depth 1
>>>> to run on Windows (as I did in the past).
>>>> However the db4geonode image does not start (goes into continuous restart loop.
>>>> Any help on this?
>>>> Pieter
>>>> _______________________________________________
>>>> geonode-devel mailing list
>>>> geonode-devel at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>> GeoServer Professional Services from the experts! Visit
>>> http://goo.gl/it488V for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> Founder/Technical Lead
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>> phone: +39 0584 962313
>>> fax: +39 0584 1660272
>>> mob: +39 331 6233686
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>> This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20200214/07d4d700/attachment-0001.html>
More information about the geonode-devel
