[GeoNode-devel] Docker db4geonode continuous restart
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Feb 14 01:51:59 PST 2020
If you want to start with a clean setup, yes, of course.
Il giorno ven 14 feb 2020 alle ore 10:51 Pieter du Plooy <
pjduplooy.gis at gmail.com> ha scritto:
> Hi Alessio
> Can I delete all images and start from scratch?
> Pieer
> On Fri, Feb 14, 2020 at 11:35 AM Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Ok, so, if you want to keep the old DB just downgrade to 10 the postgres
>> version on the Dockerfile and then run a "docker-compose up -d --build db"
>> again
>> Il giorno ven 14 feb 2020 alle ore 10:32 Pieter du Plooy <
>>> Hi Alessio.
>>> I get
>>> db4geonode       | 2020-02-14 09:29:53.638 UTC [1] FATAL:  database
>>> files are incompatible with server
>>> db4geonode       | 2020-02-14 09:29:53.638 UTC [1] DETAIL:  The data
>>> directory was initialized by PostgreSQL version 10, which is not compatible
>>> with this version 11.2 (Debian 11.2-1.pgdg90+1).
>>> Pieter
>>> On Fri, Feb 14, 2020 at 10:33 AM Alessio Fabiani <
>>>> Hi Pieter,
>>>> try a "docker-compose logs -f --tail=30 db" in order to see the logs
>>>> and try to understand what's going on.
>>>> Il giorno gio 13 feb 2020 alle ore 19:20 Pieter du Plooy <
>>>>> Hi guys.
>>>>> After a week or so away from geonode master, I did a complete rebuild
>>>>> after deleting all geonode related docker images.
>>>>> I have cloned the repo with the
>>>>> --config core.autocrlf=input --depth 1
>>>>> to run on Windows (as I did in the past).
>>>>> However the db4geonode image does not start (goes into continuous restart loop.
>>>>> Any help on this?
>>>>> Pieter
>>>>> _______________________________________________
>>>>> geonode-devel mailing list
>>>>> geonode-devel at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>> GeoServer Professional Services from the experts! Visit
>>>> http://goo.gl/it488V for more information.
>>>> Ing. Alessio Fabiani
>>>> @alfa7691
>>>> Founder/Technical Lead
>>>> GeoSolutions S.A.S.
>>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>>> phone: +39 0584 962313
>>>> fax:     +39 0584 1660272
>>>> mob:   +39 331 6233686
>>>> http://www.geo-solutions.it
>>>> http://twitter.com/geosolutions_it
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>>> precisa che ogni circostanza inerente alla presente email (il suo
>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>> This email is intended only for the person or entity to which it is
>>>> addressed and may contain information that is privileged, confidential or
>>>> otherwise protected from disclosure. We remind that - as provided by
>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>> e-mail or the information herein by anyone other than the intended
>>>> recipient is prohibited. If you have received this email by mistake, please
>>>> notify us immediately by telephone or e-mail.
>> @alfa7691
>> GeoSolutions S.A.S.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20200214/368dc1ee/attachment-0001.html>
More information about the geonode-devel mailing list
