[GeoNode-devel] Docker db4geonode continuous restart
Pieter du Plooy pjduplooy.gis at gmail.com
Fri Feb 14 01:54:49 PST 2020
I deleted all images, rebuilt from scratch, but still get the same error.
On Fri, Feb 14, 2020 at 11:52 AM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> If you want to start with a clean setup, yes, of course.
> Il giorno ven 14 feb 2020 alle ore 10:51 Pieter du Plooy <
> pjduplooy.gis at gmail.com> ha scritto:
>> Hi Alessio
>> Can I delete all images and start from scratch?
>> Pieer
>> On Fri, Feb 14, 2020 at 11:35 AM Alessio Fabiani <
>>> Ok, so, if you want to keep the old DB just downgrade to 10 the postgres
>>> version on the Dockerfile and then run a "docker-compose up -d --build db"
>>> again
>>> Il giorno ven 14 feb 2020 alle ore 10:32 Pieter du Plooy <
>>>> Hi Alessio.
>>>> I get
>>>> db4geonode       | 2020-02-14 09:29:53.638 UTC [1] FATAL:  database
>>>> files are incompatible with server
>>>> db4geonode       | 2020-02-14 09:29:53.638 UTC [1] DETAIL:  The data
>>>> directory was initialized by PostgreSQL version 10, which is not compatible
>>>> with this version 11.2 (Debian 11.2-1.pgdg90+1).
>>>> Pieter
>>>> On Fri, Feb 14, 2020 at 10:33 AM Alessio Fabiani <
>>>>> Hi Pieter,
>>>>> try a "docker-compose logs -f --tail=30 db" in order to see the logs
>>>>> and try to understand what's going on.
>>>>> Il giorno gio 13 feb 2020 alle ore 19:20 Pieter du Plooy <
>>>>>> Hi guys.
>>>>>> After a week or so away from geonode master, I did a complete rebuild
>>>>>> after deleting all geonode related docker images.
>>>>>> I have cloned the repo with the
>>>>>> --config core.autocrlf=input --depth 1
>>>>>> to run on Windows (as I did in the past).
>>>>>> However the db4geonode image does not start (goes into continuous restart loop.
>>>>>> Any help on this?
>>>>>> Pieter
>>>>>> _______________________________________________
>>>>>> geonode-devel mailing list
>>>>>> geonode-devel at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>> GeoServer Professional Services from the experts! Visit
>>>>> http://goo.gl/it488V for more information.
>>>>> Ing. Alessio Fabiani
>>>>> @alfa7691
>>>>> Founder/Technical Lead
>>>>> GeoSolutions S.A.S.
>>>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>>>> phone: +39 0584 962313
>>>>> fax:     +39 0584 1660272
>>>>> mob:   +39 331 6233686
>>>>> http://www.geo-solutions.it
>>>>> http://twitter.com/geosolutions_it
>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>> This email is intended only for the person or entity to which it is
>>>>> addressed and may contain information that is privileged, confidential or
>>>>> otherwise protected from disclosure. We remind that - as provided by
>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>> e-mail or the information herein by anyone other than the intended
>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>> notify us immediately by telephone or e-mail.
>>> @alfa7691
>>> GeoSolutions S.A.S.
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20200214/9e110b49/attachment-0001.html>
More information about the geonode-devel mailing list
