[GeoNode-devel] Docker db4geonode continuous restart
Alessio Fabiani alessio.fabiani at geo-solutions.it
Fri Feb 14 02:00:39 PST 2020
You need to purge all the volumes also (*WARNING: This will wipe out all
your data*)
This the commandline to execute to cleanup completely the docker environment
docker kill $(docker ps -q); docker rm $(docker ps -a -q); docker rmi
$(docker images -q)
; docker volume ls -qf dangling=true | xargs -r docker volume rm;
docker system prune -a
Il giorno ven 14 feb 2020 alle ore 10:55 Pieter du Plooy <
pjduplooy.gis at gmail.com> ha scritto:
> I deleted all images, rebuilt from scratch, but still get the same error.
> On Fri, Feb 14, 2020 at 11:52 AM Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> If you want to start with a clean setup, yes, of course.
>> Il giorno ven 14 feb 2020 alle ore 10:51 Pieter du Plooy <
>>> Hi Alessio
>>> Can I delete all images and start from scratch?
>>> Pieer
>>> On Fri, Feb 14, 2020 at 11:35 AM Alessio Fabiani <
>>>> Ok, so, if you want to keep the old DB just downgrade to 10 the
>>>> postgres version on the Dockerfile and then run a "docker-compose up -d
>>>> --build db" again
>>>> Il giorno ven 14 feb 2020 alle ore 10:32 Pieter du Plooy <
>>>>> Hi Alessio.
>>>>> I get
>>>>> db4geonode       | 2020-02-14 09:29:53.638 UTC [1] FATAL:  database
>>>>> files are incompatible with server
>>>>> db4geonode       | 2020-02-14 09:29:53.638 UTC [1] DETAIL:  The data
>>>>> directory was initialized by PostgreSQL version 10, which is not compatible
>>>>> with this version 11.2 (Debian 11.2-1.pgdg90+1).
>>>>> Pieter
>>>>> On Fri, Feb 14, 2020 at 10:33 AM Alessio Fabiani <
>>>>>> Hi Pieter,
>>>>>> try a "docker-compose logs -f --tail=30 db" in order to see the logs
>>>>>> and try to understand what's going on.
>>>>>> Il giorno gio 13 feb 2020 alle ore 19:20 Pieter du Plooy <
>>>>>>> Hi guys.
>>>>>>> After a week or so away from geonode master, I did a complete
>>>>>>> rebuild after deleting all geonode related docker images.
>>>>>>> I have cloned the repo with the
>>>>>>> --config core.autocrlf=input --depth 1
>>>>>>> to run on Windows (as I did in the past).
>>>>>>> However the db4geonode image does not start (goes into continuous restart loop.
>>>>>>> Any help on this?
>>>>>>> Pieter
>>>>>>> _______________________________________________
>>>>>>> geonode-devel mailing list
>>>>>>> geonode-devel at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>>>>> GeoServer Professional Services from the experts! Visit
>>>>>> http://goo.gl/it488V for more information.
>>>>>> Ing. Alessio Fabiani
>>>>>> @alfa7691
>>>>>> Founder/Technical Lead
>>>>>> GeoSolutions S.A.S.
>>>>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>>>>> phone: +39 0584 962313
>>>>>> fax:     +39 0584 1660272
>>>>>> mob:   +39 331 6233686
>>>>>> http://www.geo-solutions.it
>>>>>> http://twitter.com/geosolutions_it
>>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>>> This email is intended only for the person or entity to which it is
>>>>>> addressed and may contain information that is privileged, confidential or
>>>>>> otherwise protected from disclosure. We remind that - as provided by
>>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>>> e-mail or the information herein by anyone other than the intended
>>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>>> notify us immediately by telephone or e-mail.
>>>> @alfa7691
>>>> GeoSolutions S.A.S.
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> @alfa7691
>> GeoSolutions S.A.S.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20200214/78ac29f5/attachment-0001.html>
More information about the geonode-devel mailing list
