[GeoNode-devel] Once again: Move docs in a separate repository
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Wed Feb 26 01:51:12 PST 2020
Hi Toni,
yes, let's go for a fresh build and then changing the CNAME.
I guess Alessandro Parma, from GeoSolutions, should have access to the DNS
panel, or @Paolo Corti <pcorti at gmail.com> maybe?
Il giorno mer 26 feb 2020 alle ore 09:45 Toni Schönbuchner <
toni.schoenbuchner at csgis.de> ha scritto:
> Dear PSC members,
> once again I have to contact you regarding:
> GNIP 72 – Move docs in a separate repository
> https://github.com/GeoNode/geonode/issues/5629
> The new repository [1] is ready with branches
> *master*, *2.10*, *2.8* as discussed at GitHub [2]
> My original plan was now to just update the URL at RTD. Unfortunately
> it appears RTD keeps track of old tags and preventing users to
> wipe them out.
> As we had 2.8 tag in GitHub.com/geonode/geonode [3],
> RTD will rename our new branch to *2.8_a* to avoid conflicts.
> You can see this behaviour in my test build [4]
> To overcome this ugly naming I would suggest to use a fresh
> build https://geonode-documentation.readthedocs.io/en/master/
> and change the CNAME of docs.geonode.org for pointing
> to this new build. (Francesco kindly offered to change the
> CNAME as he has access to our domain setup).
> (As alternative we could keep the current RTF build and live with _a
> naming.)
> Cheers,
> Toni
> [1] https://github.com/GeoNode/documentation
> [2] https://github.com/GeoNode/geonode/issues/5629
> [3] https://github.com/GeoNode/geonode/tree/2.8
> [4] https://cs-geonode.readthedocs.io/en/2.10/
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20200226/7bec850f/attachment.html>
More information about the geonode-devel
