[GeoNode-devel] GeoNode 3.x Advanced Installation and uwsgi issue
Paolo Pasquali paolo.pasquali at gmail.com
Thu Nov 5 09:26:15 PST 2020
Thank you, Alessio.
I get this error.
$ uwsgi -c /etc/uwsgi/apps-available/geonode.ini
[uWSGI] getting INI configuration from /etc/uwsgi/apps-available/geonode.ini
open("./python3_plugin.so"): No such file or directory [core/utils.c line
3732]
!!! UNABLE to load uWSGI plugin: ./python3_plugin.so: cannot open shared
object file: No such file or directory !!!
The plugin is located at
$ locate python3_plugin.so
/usr/lib/uwsgi/plugins/python3_plugin.so
So if I remove from the geonode.ini file plugins = python3
And then I still get
$ sudo service uwsgi start
Job for uwsgi.service failed because the control process exited with error
code.
Maybe because from the log
Thu Nov  5 17:47:50 2020 - *** Operational MODE: preforking ***
Thu Nov  5 17:47:50 2020 - *** no app loaded. GAME OVER ***
Thu Nov  5 17:47:50 2020 - VACUUM: unix socket
/run/uwsgi/app/geonode/socket removed.
Any hint or cue on this?
Thanks!
Paolo
On Thu, Nov 5, 2020 at 3:01 PM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Hi Paolo,
> from the logs I cannot recognize any specific issue.
> It might depend on some error during the application initialization.
> You could do a simple test by trying to run uwsgi from the command line,
> e.g.:
> uwsgi -c <path to the uwsgi config ini>
> Il giorno gio 5 nov 2020 alle ore 10:44 Paolo Pasquali <
> paolo.pasquali at gmail.com> ha scritto:
>> Dear devs,
>> I'm following the 3.x documentation for installing GeoNode on Ubuntu 20
>> without docker.
>> At some point I have to create the uwsgi geonode.ini [1] file.
>> I have updated the paths in the geonode.ini file according to my
>> installation and the first thing I have noticed is that I need to add
>> uid = geonode
>> or I get a permission denied error when I try to start the service. That
>> was omitted in the 3.x doc.
>> Then I get another error.
>> error code.
>> See "systemctl status uwsgi.service" and "journalctl -xe" for details.
>> $ systemctl status uwsgi.service
>> *●* uwsgi.service - LSB: Start/stop uWSGI server instance(s)
>>      Loaded: loaded (/etc/init.d/uwsgi; generated)
>>      Active: *failed* (Result: exit-code) since Thu 2020-11-05 10:02:52
>> CET; 14s ago
>>        Docs: man:systemd-sysv-generator(8)
>>     Process: 208347 ExecStart=/etc/init.d/uwsgi start *(code=exited,
>> status=1/FAILURE)*
>>       Tasks: 9 (limit: 19114)
>> Some uwgi processes are active anyway.
>> I'm attaching the log file. Could you please help me understand the error
>> I'm getting?
>> I can see an "unable to find requested cheaper algorithm, falling back to
>> spare" which is new from 2.10.
>> Thanks!
>> Regards,
>> Paolo
>> [1]
>> https://docs.geonode.org/en/3.x/install/advanced/core/index.html#serving-geonode-geoserver-via-nginx
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20201105/b69c137c/attachment-0001.html>
More information about the geonode-devel mailing list
