[GeoNode-devel] GeoNode 3.x Advanced Installation and uwsgi issue
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Thu Nov 5 10:09:34 PST 2020
Paolo,
it looks like you are not using the correct python environment.
I guess you need to activate it before running UWSGI.
Il giorno gio 5 nov 2020 alle ore 18:26 Paolo Pasquali <
paolo.pasquali at gmail.com> ha scritto:
> Thank you, Alessio.
> I get this error.
> $ uwsgi -c /etc/uwsgi/apps-available/geonode.ini
> [uWSGI] getting INI configuration from
> open("./python3_plugin.so"): No such file or directory [core/utils.c line
> 3732]
> !!! UNABLE to load uWSGI plugin: ./python3_plugin.so: cannot open shared
> object file: No such file or directory !!!
> The plugin is located at
> $ locate python3_plugin.so
> /usr/lib/uwsgi/plugins/python3_plugin.so
> So if I remove from the geonode.ini file plugins = python3
> And then I still get
> $ sudo service uwsgi start
> Job for uwsgi.service failed because the control process exited with error
> code.
> Maybe because from the log
> Thu Nov 5 17:47:50 2020 - *** Operational MODE: preforking ***
> Thu Nov 5 17:47:50 2020 - *** no app loaded. GAME OVER ***
> Thu Nov 5 17:47:50 2020 - VACUUM: unix socket
> /run/uwsgi/app/geonode/socket removed.
> Any hint or cue on this?
> Thanks!
> Paolo
> On Thu, Nov 5, 2020 at 3:01 PM Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> wrote:
>> Hi Paolo,
>> from the logs I cannot recognize any specific issue.
>> It might depend on some error during the application initialization.
>> You could do a simple test by trying to run uwsgi from the command line,
>> e.g.:
>> uwsgi -c <path to the uwsgi config ini>
>> Il giorno gio 5 nov 2020 alle ore 10:44 Paolo Pasquali <
>>> Dear devs,
>>> I'm following the 3.x documentation for installing GeoNode on Ubuntu 20
>>> without docker.
>>> At some point I have to create the uwsgi geonode.ini [1] file.
>>> I have updated the paths in the geonode.ini file according to my
>>> installation and the first thing I have noticed is that I need to add
>>> uid = geonode
>>> or I get a permission denied error when I try to start the service. That
>>> was omitted in the 3.x doc.
>>> Then I get another error.
>>> error code.
>>> See "systemctl status uwsgi.service" and "journalctl -xe" for details.
>>> $ systemctl status uwsgi.service
>>> *●* uwsgi.service - LSB: Start/stop uWSGI server instance(s)
>>> Loaded: loaded (/etc/init.d/uwsgi; generated)
>>> Active: *failed* (Result: exit-code) since Thu 2020-11-05 10:02:52
>>> CET; 14s ago
>>> Docs: man:systemd-sysv-generator(8)
>>> Process: 208347 ExecStart=/etc/init.d/uwsgi start *(code=exited,
>>> status=1/FAILURE)*
>>> Tasks: 9 (limit: 19114)
>>> Some uwgi processes are active anyway.
>>> I'm attaching the log file. Could you please help me understand the
>>> error I'm getting?
>>> I can see an "unable to find requested cheaper algorithm, falling back
>>> to spare" which is new from 2.10.
>>> Thanks!
>>> Regards,
>>> Paolo
>>> [1]
>>> https://docs.geonode.org/en/3.x/install/advanced/core/index.html#serving-geonode-geoserver-via-nginx
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>> phone: +39 0584 962313
>> fax: +39 0584 1660272
>> mob: +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20201105/246d65d2/attachment-0001.html>
More information about the geonode-devel
