[GeoNode-devel] GeoNode 3.x Advanced Installation and uwsgi issue
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Thu Nov 5 10:11:59 PST 2020
It is also worth to take a look at this
https://stackoverflow.com/questions/41535283/unable-to-load-uwsgi-plugin-python3-plugin-so-cannot-open-shared-object-file
it seems that someone solved the issue by adding a "plugins-dir" directive
to the conf.
Il giorno gio 5 nov 2020 alle ore 19:09 Alessio Fabiani <
alessio.fabiani at geo-solutions.it> ha scritto:
> Paolo,
> it looks like you are not using the correct python environment.
> I guess you need to activate it before running UWSGI.
> Il giorno gio 5 nov 2020 alle ore 18:26 Paolo Pasquali <
> paolo.pasquali at gmail.com> ha scritto:
>> Thank you, Alessio.
>> I get this error.
>> $ uwsgi -c /etc/uwsgi/apps-available/geonode.ini
>> [uWSGI] getting INI configuration from
>> open("./python3_plugin.so"): No such file or directory [core/utils.c line
>> 3732]
>> !!! UNABLE to load uWSGI plugin: ./python3_plugin.so: cannot open shared
>> object file: No such file or directory !!!
>> The plugin is located at
>> $ locate python3_plugin.so
>> /usr/lib/uwsgi/plugins/python3_plugin.so
>> So if I remove from the geonode.ini file plugins = python3
>> And then I still get
>> $ sudo service uwsgi start
>> Job for uwsgi.service failed because the control process exited with
>> error code.
>> Maybe because from the log
>> Thu Nov 5 17:47:50 2020 - *** Operational MODE: preforking ***
>> Thu Nov 5 17:47:50 2020 - *** no app loaded. GAME OVER ***
>> Thu Nov 5 17:47:50 2020 - VACUUM: unix socket
>> /run/uwsgi/app/geonode/socket removed.
>> Any hint or cue on this?
>> Thanks!
>> Paolo
>> On Thu, Nov 5, 2020 at 3:01 PM Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it> wrote:
>>> Hi Paolo,
>>> from the logs I cannot recognize any specific issue.
>>> It might depend on some error during the application initialization.
>>> You could do a simple test by trying to run uwsgi from the command line,
>>> e.g.:
>>> uwsgi -c <path to the uwsgi config ini>
>>> Il giorno gio 5 nov 2020 alle ore 10:44 Paolo Pasquali <
>>>> Dear devs,
>>>> I'm following the 3.x documentation for installing GeoNode on Ubuntu 20
>>>> without docker.
>>>> At some point I have to create the uwsgi geonode.ini [1] file.
>>>> I have updated the paths in the geonode.ini file according to my
>>>> installation and the first thing I have noticed is that I need to add
>>>> uid = geonode
>>>> or I get a permission denied error when I try to start the service.
>>>> That was omitted in the 3.x doc.
>>>> Then I get another error.
>>>> error code.
>>>> See "systemctl status uwsgi.service" and "journalctl -xe" for details.
>>>> $ systemctl status uwsgi.service
>>>> *●* uwsgi.service - LSB: Start/stop uWSGI server instance(s)
>>>> Loaded: loaded (/etc/init.d/uwsgi; generated)
>>>> Active: *failed* (Result: exit-code) since Thu 2020-11-05
>>>> 10:02:52 CET; 14s ago
>>>> Docs: man:systemd-sysv-generator(8)
>>>> Process: 208347 ExecStart=/etc/init.d/uwsgi start *(code=exited,
>>>> status=1/FAILURE)*
>>>> Tasks: 9 (limit: 19114)
>>>> Some uwgi processes are active anyway.
>>>> I'm attaching the log file. Could you please help me understand the
>>>> error I'm getting?
>>>> I can see an "unable to find requested cheaper algorithm, falling back
>>>> to spare" which is new from 2.10.
>>>> Thanks!
>>>> Regards,
>>>> Paolo
>>>> [1]
>>>> https://docs.geonode.org/en/3.x/install/advanced/core/index.html#serving-geonode-geoserver-via-nginx
>>>> _______________________________________________
>>>> geonode-devel mailing list
>>>> geonode-devel at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>> GeoServer Professional Services from the experts! Visit
>>> http://goo.gl/it488V for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> Founder/Technical Lead
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>> phone: +39 0584 962313
>>> fax: +39 0584 1660272
>>> mob: +39 331 6233686
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>> This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20201105/1e5b4cdf/attachment-0001.html>
More information about the geonode-devel
