[GeoNode-devel] Create Layer menu don't appear
Toni Schönbuchner
toni.schoenbuchner at csgis.de
Wed Nov 18 12:08:09 PST 2020
Hi Joao,
have you seen:
https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L1288 <https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L1288>
Yes you can use .env to change your vars. I’m not using SPC but would
suggest to stay in it’s .env file or create a second and load it in docker-compose.yml
(Similar to here: https://github.com/GeoNode/geonode-project/issues/152)
Cheers,
Toni
> Von: João Gaspar <joao.f.r.gaspar at gmail.com>
> Betreff: [GeoNode-devel] [Docker][SPCGeonode] Create Layer menu don't appear
> Datum: 18. November 2020 um 11:41:22 MEZ
> An: geonode-devel <geonode-devel at lists.osgeo.org>
> Hi Devs,
> I did a fresh install of SPCGeonode, yesterday (17-11-2020) to master (3.1).
> I notice that the master.geonode.org <http://master.geonode.org/> have in navbar the menu Data > Create Layer.
> In my fresh install don't appear this menu.
> I change SPCGeonode .env file for the IP of machine and change settings.py (probably the worst option to do), where it says localhost.
> Please let me know if is necessary to send the .env file and settings.py.
> Another thing where I'm doubts (probably related with this issue,
> is where we put the VARIABLES of geonode that we want overwrite? We add In .env from spcgeonode folder or use the normal .env of geonode?
> Cheers,
> João Gaspar
> geonode-devel mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20201118/59678ee8/attachment.html>
More information about the geonode-devel
