[GeoNode-devel] GeoServer crashed in GeoNode 2.10
Paolo Pasquali
paolo.pasquali at gmail.com
Mon Nov 23 11:03:36 PST 2020
Finally!
GeoServer starts with jdk11.
In the previous email I stated it didn't but I forgot to update the
setenv.sh file (so it was still pointing to java8).
I wonder what happened.
Ciao
P.
On Mon, Nov 23, 2020 at 7:42 PM Paolo Pasquali <paolo.pasquali at gmail.com>
wrote:
> I've upgraded the jdk to 11 but with no result.
> Stopped Tomcat and started GeoServer with paver and it works.
> On Mon, Nov 23, 2020 at 6:24 PM Paolo Pasquali <paolo.pasquali at gmail.com>
> wrote:
>> Ciao Alessio,
>> I have a production installation made in GeoNode 2.10 with some python2
>> customizations whose GeoServer suddenly crashed. So I cannot easily upgrade.
>> So I made another 2.10 installation in order to tackle the issue. Without
>> much luck.
>> On Mon, Nov 23, 2020 at 6:21 PM Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it> wrote:
>>> Hello Paolo,
>>> if you are doing a fresh installation, why are you using GeoNode 2.10?
>>> Il giorno lun 23 nov 2020 alle ore 18:10 Paolo Pasquali <
>>> paolo.pasquali at gmail.com> ha scritto:
>>>> Hi,
>>>> Sorry for the spam.
>>>> I made a fresh installation and an empty GeoServer crashed after the
>>>> first restart when I was configuring uwgi and nginx (2.10 Advanced
>>>> installation on Ubuntu 18).
>>>> I'm not able to start it again in any way. I'm getting the same errors
>>>> on the two servers.
>>>> Is there any known issue? Should I upgrade java to 11?
>>>> Thanks,
>>>> P.
>>>> On Mon, Nov 23, 2020 at 2:41 PM Paolo Pasquali <
>>>> paolo.pasquali at gmail.com> wrote:
>>>>> Dear devs,
>>>>> Please find attached the full geoserver.log since tomcat restart and
>>>>> after removing the out of sync gwc layers.
>>>>> Thanks.
>>>>> Ciao
>>>>> P.
>>>>> On Mon, Nov 23, 2020 at 12:37 PM Paolo Pasquali <
>>>>>> Dear devs,
>>>>>> I've removed all layer configuration files in gwc-layers that were
>>>>>> causing errors but still GeoServer does not start.
>>>>>> The Tomcat log file caught some errors:
>>>>>> 23-Nov-2020 11:26:58.714 SEVERE [localhost-startStop-1]
>>>>>> org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks
>>>>>> The web application [geoserver] created a ThreadLocal with key of type
>>>>>> [com.sun.jna.Structure$2] (value [com.sun.jna.Structure$2 at 26050621])
>>>>>> and a value of type [com.sun.jna.Structure.StructureSet] (value [[]]) but
>>>>>> failed to remove it when the web application was stopped. Threads are going
>>>>>> to be renewed over time to try and avoid a probable memory leak.
>>>>>> [java.lang.ThreadLocal] (value [java.lang.ThreadLocal at 215fba9b]) and
>>>>>> a value of type
>>>>>> [org.springframework.security.core.context.SecurityContextImpl] (value
>>>>>> [org.springframework.security.core.context.SecurityContextImpl at ffffffff:
>>>>>> Null authentication]) but failed to remove it when the web application was
>>>>>> stopped. Threads are going to be renewed over time to try and avoid a
>>>>>> 23-Nov-2020 11:26:58.723 SEVERE [localhost-startStop-1]
>>>>>> [java.lang.ThreadLocal] (value [java.lang.ThreadLocal at 53488849]) and
>>>>>> a value of type
>>>>>> [org.geotools.referencing.operation.projection.TransverseMercator.Provider]
>>>>>> (value [PROJECTION["Transverse_Mercator"]]) but failed to remove it when
>>>>>> the web application was stopped. Threads are going to be renewed over time
>>>>>> [java.lang.ThreadLocal.SuppliedThreadLocal] (value
>>>>>> [java.lang.ThreadLocal$SuppliedThreadLocal at 1c220bed]) and a value of
>>>>>> type [org.geowebcache.storage.CompositeBlobStore.StoreSuitabilityCheck]
>>>>>> (value [EXISTING]) but failed to remove it when the web application was
>>>>>> While the GeoServer log has some warnings only, some are:
>>>>>> 2020-11-23 11:31:42,676 WARN [geoserver.config] - Error reading
>>>>>> resource URL
>>>>>> [jar:file:/usr/local/apache-tomcat8/webapps/geoserver/WEB-INF/lib/gs-geofence-server-2.15-SNAPSHOT.jar!/geofence-default-override.properties]
>>>>>> java.io.FileNotFoundException: URL
>>>>>> cannot be resolved to absolute file path because it does not reside in the
>>>>>> file system:
>>>>>> 2020-11-23 11:31:43,581 WARN [ejb.Ejb3Configuration] -
>>>>>> hibernate.connection.autocommit = false break the EJB3 specification
>>>>>> 2020-11-23 11:31:43,613 WARN [dialect.H2Dialect] - The 1.1.119
>>>>>> version of H2 implements temporary table creation such that it commits
>>>>>> current transaction; multi-table, bulk hql/jpaql will not work properly
>>>>>> 2020-11-23 11:31:43,863 WARN [dialect.H2Dialect] - The 1.1.119
>>>>>> 2020-11-23 11:31:44,033 WARN [cache.EhCacheProvider] - Could not find
>>>>>> configuration [RuleLimits]; using defaults.
>>>>>> 2020-11-23 11:31:44,077 WARN [cache.EhCacheProvider] - Could not find
>>>>>> configuration [Rule]; using defaults.
>>>>>> 2020-11-23 11:31:44,085 WARN [cache.EhCacheProvider] - Could not find
>>>>>> configuration [usergroup]; using defaults.
>>>>>> 2020-11-23 11:31:44,090 WARN [cache.EhCacheProvider] - Could not find
>>>>>> configuration [GSUser]; using defaults.
>>>>>> 2020-11-23 11:31:44,096 WARN [cache.EhCacheProvider] - Could not find
>>>>>> configuration [GFUser]; using defaults.
>>>>>> 2020-11-23 11:31:44,101 WARN [cache.EhCacheProvider] - Could not find
>>>>>> configuration [gsinstance]; using defaults.
>>>>>> 2020-11-23 11:31:44,107 WARN [cache.EhCacheProvider] - Could not find
>>>>>> configuration [LayerDetails]; using defaults.
>>>>>> 2020-11-23 11:31:45,527 WARN [org.geoserver] - Failed to load data
>>>>>> store 'geonode_data'
>>>>>> Any hint on how to proceed?
>>>>>> Thanks!
>>>>>> Paolo
>>>>>> On Mon, Nov 23, 2020 at 10:28 AM Paolo Pasquali <
>>>>>>> Dear devs,
>>>>>>> While updating some layers metadata using the GeoNode admin UI,
>>>>>>> suddenly GeoServer crashed and now I'm not able to restart it anymore.
>>>>>>> From the logs I get some errors:
>>>>>>> ERROR [context.ContextLoader] - Context initialization failed
>>>>>>> org.springframework.beans.factory.BeanCreationException: Error
>>>>>>> creating bean with name 'wcsService-1.0.0' defined in URL
>>>>>>> Invocation of init method failed; nested exception is
>>>>>>> java.lang.IllegalStateException: Could not locate a layer or layer group
>>>>>>> with id LayerInfoImpl-52979d4a:172b8fc663e:-33fe within GeoServer
>>>>>>> configuration, the GWC configuration seems to be out of synch
>>>>>>> I have this kind of error related to several layers. My guess they
>>>>>>> are related to the layers I tried to update in the admin ui.
>>>>>>> The solution I've found on the web suggests removing the layers from
>>>>>>> the gwc-layers folders and then running updatelayers.
>>>>>>> Is this the only solution? Is there a painless fix?
>>>>>>> Thanks for your help.
>>>>>>> Ciao
>>>>>>> P.
>>>>>>> _______________________________________________
>>>> geonode-devel mailing list
>>>> geonode-devel at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>> GeoServer Professional Services from the experts! Visit
>>> http://goo.gl/it488V for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> Founder/Technical Lead
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>> phone: +39 0584 962313
>>> fax: +39 0584 1660272
>>> mob: +39 331 6233686
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>> This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20201123/53cc06bc/attachment-0001.html>
More information about the geonode-devel
