[GeoNode-devel] GeoNode 2.10 Error on documents
Paolo Pasquali
paolo.pasquali at gmail.com
Tue Nov 24 05:28:09 PST 2020
Solved.
There were some documents that had some issues while they have been
uploaded because some services were down.
So I removed the docs and uploaded them again and now the list is ok.
Bye,
P.
On Tue, Nov 24, 2020 at 11:25 AM Paolo Pasquali <paolo.pasquali at gmail.com>
wrote:
> Dear devs,
> I'm getting an error on documents. The list of documents does not appear
> but if I apply some filters (e.g. Document Type) the list seems correct. I
> have no problem on layer and map lists.
> Should I check out-of-date custom templates (e.g. search templates)? I've
> upgraded from 2.10.2 to 2.10.4.
> Please find the error below.
> Thanks for your help.
> Best,
> Paolo
> Internal Server Error: /api/documents/
> Traceback (most recent call last):
> File
> "/home/ubuntu/.virtualenvs/haitidata/local/lib/python2.7/site-packages/tastypie/resources.py",
> line 227, in wrapper
> response = callback(request, *args, **kwargs)
> File
> line 467, in dispatch_list
> return self.dispatch('list', request, **kwargs)
> File
> line 499, in dispatch
> response = method(request, **kwargs)
> File
> "/home/ubuntu/.virtualenvs/haitidata/local/lib/python2.7/site-packages/geonode/api/resourcebase_api.py",
> line 582, in get_list
> request, to_be_serialized, response_objects=objects)
> File
> line 650, in create_response
> data['objects'])) if x['id'] in filtered_objects_ids]
> File
> line 1029, in format_objects
> username = obj.owner.get_username()
> AttributeError: 'NoneType' object has no attribute 'get_username'
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20201124/3f2b55b4/attachment.html>
More information about the geonode-devel
