[GeoNode-devel] Catalog menu (search/result) - Mapstore
Toni Schönbuchner
toni.schoenbuchner at csgis.de
Tue Nov 24 06:06:25 PST 2020
Hi Simone,
from what I see it’s set in the reducer.
https://github.com/geosolutions-it/MapStore2/blob/023a1ed1a41a43fe98122adb7a803e00a55753e3/web/client/reducers/catalog.js#L60 <https://github.com/geosolutions-it/MapStore2/blob/023a1ed1a41a43fe98122adb7a803e00a55753e3/web/client/reducers/catalog.js#L60>
If I’m correct you would need to create a new build with a changed value.
Cheers,
Toni
> Am 24.11.2020 um 14:24 schrieb geonode-devel-owner at lists.osgeo.org:
> Hi,
> I’m writing to ask about the Mapstore inside the Geonode.
> Is it possible to modify the number of items in the search/result section of the catalog side menu?
> Currently it is possible to see four elements per page but I should modify it in order to see almost all the layers that I have in the catalog.
> Thanks for your attention.
> Best regards
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20201124/1c5d5233/attachment.html>
More information about the geonode-devel
