[GeoNode-devel] Bootstrap 3 EOL
Toni Schönbuchner toni.schoenbuchner at csgis.de
Tue Nov 24 06:56:45 PST 2020
Hi Paolo,
unfortunately the client jumped off at that time and the PR was closed unfinished.
+1 for working on this. The only thing we should keep in mind is that the navigation
bar will get breaking changes with newer bs which might cause troubles for geonode project users.
best,
Toni
> Am 24.11.2020 um 15:39 schrieb Paolo Pasquali <paolo.pasquali at gmail.com>:
> Hi Toni, Devs,
> Has any decision been made about it? I see an old gnip: https://github.com/GeoNode/geonode/issues/4901 <https://github.com/GeoNode/geonode/issues/4901>
> Maybe I can help with this.
> Or is there someone working in a different direction?
> Thanks.
> Best,
> P.
> On Fri, Sep 13, 2019 at 4:52 PM Toni Schönbuchner <toni.schoenbuchner at csgis.de <mailto:toni.schoenbuchner at csgis.de>> wrote:
> Hi Paolo,
> I would see it backported if possible.
> @Alessio @Francesco: Thanks !
> Cheers,
> Toni
> > Am 13.09.2019 um 15:43 schrieb Paolo Corti <pcorti at gmail.com <mailto:pcorti at gmail.com>>:
> > +1
> > would this go just to master, or backported as well?
> > Paolo
> > On Fri, Sep 13, 2019 at 9:01 AM Francesco Bartoli <xbartolone at gmail.com <mailto:xbartolone at gmail.com>> wrote:
> >> +1 as well, count it in the GNIP
> >> Il 13 set 2019, 12:54 +0200, Alessio Fabiani <alessio.fabiani at geo-solutions.it <mailto:alessio.fabiani at geo-solutions.it>>, ha scritto:
> >> Dear Toni,
> >> that would be great!
> >> You have my great +1
> >> However, we should formally pass through a GNIP.
> >> Il giorno ven 13 set 2019 alle ore 12:28 Toni Schönbuchner <toni.schoenbuchner at csgis.de <mailto:toni.schoenbuchner at csgis.de>> ha scritto:
> >>> Dear Devs,
> >>> we’re currently using bootstrap 3.4 (active LTS Start 2014-11-01) which has reached EOL.
> >>> https://github.com/twbs/release <https://github.com/twbs/release>
> >>> https://blog.getbootstrap.com/2019/07/24/lts-plan/ <https://blog.getbootstrap.com/2019/07/24/lts-plan/>
> >>> To stay up-to-date we should consider upgrading to version 4.
> >>> Breaking Changes in Version 4
> >>> A) LESS > SASS
> >>> Bootstrap 4 moved from LESS to SASS.
> >>> We would need to convert:
> >>> https://github.com/GeoNode/geonode/tree/master/geonode/static/geonode/less <https://github.com/GeoNode/geonode/tree/master/geonode/static/geonode/less>
> >>> https://github.com/GeoNode/geonode/tree/master/geonode/static/geonode/css <https://github.com/GeoNode/geonode/tree/master/geonode/static/geonode/css>
> >>> B) Browser Support
> >>> Version 4 does not support Internet Explorer 8, 9, and iOS 6 anymore!
> >>> C) Dropped Glyphicons
> >>> Bootstrap no longer includes Glyphicons. Instead, you’re advised to find your own favourites and include them in whichever way you see fit.
> >>> F.e.: https://useiconic.com/open/ <https://useiconic.com/open/> or https://octicons.github.com/ <https://octicons.github.com/>
> >>> What we get
> >>> - ! Security Fixes (XSS vulnerabilities pop up quite often) !
> >>> - Cards https://coreui.io/docs/components/cards/ <https://coreui.io/docs/components/cards/> (Could be useful for featured maps)
> >>> - A more advanced Grid System
> >>> - All JS Plugins use ES6
> >>> - Flexbox
> >>> - Reboot instead of Normalize.css
> >>> - Better Variable handling (Vars not split around severals files anymore)
> >>> - Rem instead of px. (more scalable)
> >>> - New breakpoints
> >>> Before opening a GNIP I would ask if there are voices against an upgrade?
> >>> Cheers,
> >>> Toni
> >>> CSGIS
> >>> Gottschedstraße 12
> >>> 04109 Leipzig
> >>> Telefon 0341. 39 37 3397
> >>> Web https://csgis.de <https://csgis.de/>
> >>> Hinweis gemäß § 33 BDSG
> >>> Daten der Verfahrensbeteiligten werden gespeichert. Dieses Dokument ist ausschließlich für den
> >>> Adressaten bestimmt. Der Inhalt der E-Mail ist vertraulich. Falls Sie diese E-Mail versehentlich
> >>> erhalten haben, rufen Sie uns unter obiger Rufnummer umgehend an und löschen Sie diese Nachricht
> >>> von Ihrem Computer. Jegliche Art von Reproduktionen, Verbreitung, Vervielfältigung, Veränderung,
> >>> Verteilung und/oder Veröffentlichung dieser E-Mail ist verboten.
> >>> _______________________________________________
> >>> geonode-devel mailing list
> >>> geonode-devel at lists.osgeo.org <mailto:geonode-devel at lists.osgeo.org>
> >>> https://lists.osgeo.org/mailman/listinfo/geonode-devel <https://lists.osgeo.org/mailman/listinfo/geonode-devel>
> >> GeoServer Professional Services from the experts! Visit http://goo.gl/it488V <http://goo.gl/it488V> for more information.
> >> Ing. Alessio Fabiani
> >> @alfa7691
> >> Founder/Technical Lead
> >> GeoSolutions S.A.S.
> >> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> >> phone: +39 0584 962313
> >> fax: +39 0584 1660272
> >> mob: +39 331 6233686
> >> http://www.geo-solutions.it <http://www.geo-solutions.it/>
> >> http://twitter.com/geosolutions_it <http://twitter.com/geosolutions_it>
> >> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> >> This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
> > Paolo Corti
> > Geospatial software developer
> > web: http://www.paolocorti.net <http://www.paolocorti.net/>
> > twitter: @capooti
> > skype: capooti
> > #drt3jc1
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20201124/f33cddf0/attachment-0001.html>
More information about the geonode-devel mailing list
