[GeoNode-devel] How to connect / synchronize two GeoNode Instances
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Thu Apr 8 06:19:06 PDT 2021
Hi Florian,
for some of our customers we use the GeoNode backup/restore mechanism
inside the docker containers along with Jenkins
[image: image.png]
I'm going to attach some advanced scripts we are currently using for this
customer. They are almost the same present into the GeoNode core.
Alessio.
P.S.: notice that this fix
<https://osgeo-org.atlassian.net/browse/GEOS-10005> is not included into
the current GeoServer distribution for GeoNode, but this does not prevent
BR to work
Il giorno gio 8 apr 2021 alle ore 12:33 Florian Hoedt <
florian.hoedt at thuenen.de> ha scritto:
> Hi Developers,
> We want to connect / synchronize multiple GeoNode instances. For example
> one instance is open for external project partners, our main instance is
> only for internal usage. The idea is to pull layers and documents into the
> main instance. Are there good and proven ways to do so?
> yours,
> Florian
> MSc Florian Hoedt
> Head Geoinformatics | OpenData Representative
> Thünen Institute, Centre for Information Management
> Bundesallee 44
> 38116 Braunschweig
> Tel: +49 531 596-1428
> Mobil: +49 162 92 50 275
> Fax: +49 531 596-1499
> Mail: florian.hoedt at thuenen.de
> Web: www.thuenen.de
> The Johann Heinrich von Thünen Institute, Federal Research Institute for
> Rural Areas, Forestry and Fisheries – Thünen Institute in brief – consists
> of 14 specialized institutes that carry out research and provide policy
> advice in the fields of economy, ecology and technology.
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20210408/5433cd0f/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20210408/5433cd0f/attachment-0001.png>
Type: application/x-zip-compressed
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20210408/5433cd0f/attachment-0001.bin>
More information about the geonode-devel
