[GeoNode-devel] Stability of branches during refactoring and cleanup
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Fri Apr 9 02:54:10 PDT 2021
Dear Adrian,
please see below a first draft of the upcoming 3.2.0 release changelog
Change Log3.2.0 <https://github.com/GeoNode/geonode/tree/3.2.0>
(2021-04)Breaking
Changes
- Bump to postgresql-13
- Based on MapStore client 2.1.3
<https://github.com/GeoNode/geonode-mapstore-client/releases/tag/2.1.3>
- MapStore client is no more compatible with 3.0.x train
- ResourceBase Model BBOX now is a geometry; that is no more compatible
with the 3.1.x one
- GNIP-81: GeoNode Core Cleanup
<https://github.com/GeoNode/geonode/issues/6917>:
- Removed GeoNetwork support
- Removed QGIS-Server support
- Removed SPC GeoNode support
- Advanced Resources Publishing Logic has been revised (see below)
Features
Python upgrade 3.7+
Django upgrade 2.2.16+
GeoServer upgrade 2.18.2
MapStore2 Client Updates:
- Save Search Services to the Map
- Save Map Preferences into the adapter model
- Advanced Style Editor with graphical UI
- Improved Map Save Widget, specific for GeoNode
- New MapStore client configuration subsytem
Upgraded Dokerfile and docker-compose to version 3.4
Migration of CI from Travis to CircleCI
General Code Quality and Performance Improvements
Highlights GeoNode 3.2:
- GNIP-76: Add RTL Support
<https://github.com/GeoNode/geonode/issues/6156>
- GNIP-77: GetFeatureInfo Templating For GeoNode
<https://github.com/GeoNode/geonode/issues/6182>
- GNIP-78: GeoNode generic "Apps" model to include pluggable entities
into the framework <https://github.com/GeoNode/geonode/issues/6684>
- GNIP-79: GeoNode REST APIs (v2)
<https://github.com/GeoNode/geonode/issues/6685>
- GNIP-82: Thesauri improvements
<https://github.com/GeoNode/geonode/issues/6925>
- GNIP-83: ResourceBase for metadata-only resources
<https://github.com/GeoNode/geonode/issues/7057>
- GNIP-84: Upload Page Enhancements
<https://github.com/GeoNode/geonode/issues/7154>
- GNIP-85: Map legend <https://github.com/GeoNode/geonode/issues/7254>
- GNIP 86: metadata parsing and storing
<https://github.com/GeoNode/geonode/issues/7263>
- Append data to an existing layer feature
- Improved Metadata Editors, now able to handle HTML tags
- Improved Catalog and Thesauri
- Possibility to Upload RDF thesaurus via web
- Pluggable CSW prefiltering from external apps
- Delete existing table on restore command feature (general
improvements to Backup/Restore machinery)
- Advanced Upload Workflow Improvements:
- Non admin user cannot change permission
- Disable edit permissions globally when read-only mode is active
- RESOURCE_PUBLISHING:
1. "unpublished" won't be visibile to Anonymous users
2. "unpublished" will be visible to registered users IF they
have view permissions
3. "unpublished" will be always visible to the owner and Group
Managers
By default the uploaded resources will be "unpublished".
The owner will be able to change them to "published" UNLESS the
ADMIN_MODERATE_UPLOADS is activated.
If the owner assigns unpublished resources to a Group, both
from Metadata and Permissions, in any case the Group
"Managers" will be
able to edit the Resource.
- ADMIN_MODERATE_UPLOADS:
1. The owner won't be able to change to neither "approved" nor
"published" state (unless he is a superuser)
2. If the Resource belongs to a Group somehow, the Managers
will be able to change the state to "approved"
but NOT to "published". Only a superuser can publish a resource.
3. Superusers can do enything.
- GROUP_PRIVATE_RESOURCES:
The "unapproved" and "unpublished" Resources will be accessible
ONLY by owners, superusers and member of the belonging groups.
- GROUP_MANDATORY_RESOURCES:
Editor will be FORCED to select a Group when editing the resource
metadata.
Documentation Updates:
- GetFeatureInfo Templating For GeoNode
<https://docs.geonode.org/en/master/usage/managing_maps/exploring_maps/get_fetureinfo.html?highlight=GetFeatureInfo>
- HowTo: Geonode with QGIS
<https://docs.geonode.org/en/master/usage/other_apps/qgis/index.html>
- Improve GeoNode OpenID SP Protocol in order to be able to provide
access to external clients
<https://docs.geonode.org/en/master/usage/other_apps/qgis/index.html?highlight=Connect%20to%20Private%20layers%20by%20using%20OAuth2#connect-to-private-layers-by-using-oauth2>
- Document the use of slide show in themes
<https://docs.geonode.org/en/master/admin/admin_panel/index.html?highlight=Slide%20show#slide-show>
- Update Advanced Installation steps to work against Ubuntu 20.04LTS
<https://docs.geonode.org/en/master/install/advanced/core/index.html?highlight=Ubuntu%2020.04LTS#ubuntu-20-04lts>
- Update Advanced Installation steps to work against RHEL 7.x
<https://docs.geonode.org/en/master/install/advanced/core/index.html?highlight=Ubuntu%2020.04LTS#rhel-7-x>
- How to setup rabbitmq, supervisor and memcached in order to fully
enable async workers
<https://docs.geonode.org/en/master/install/advanced/core/index.html?highlight=Enabling%20Fully%20Asynchronous%20Tasks#enabling-fully-asynchronous-tasks>
- How to Upgrade from 2.10.x / 3.0
<https://docs.geonode.org/en/master/admin/upgrade/index.html?highlight=Upgrade%20from%202.10.x>
- Docs to connect production docker to external postgreSQL db server
<https://github.com/GeoNode/documentation/pull/74>
- Documentantion for new metadata settings
<https://github.com/GeoNode/documentation/pull/75>
- Refers #6925: add documentation for thesaurus configuration
<https://github.com/GeoNode/documentation/pull/77>
- Refers #6952: add documentantion for uuidhandler
<https://github.com/GeoNode/documentation/pull/78>
- Adding new settings in order to let the optional metadata in
metadata wizard to become required
<https://github.com/GeoNode/documentation/pull/84>
- Remove outdated/misleading SPC GeoNdoe documentation
<https://github.com/GeoNode/documentation/pull/85>
- Relates to #7089 Delete existing table on restore
<https://github.com/GeoNode/documentation/pull/86>
- Allow XSL customization
<https://github.com/GeoNode/documentation/pull/87>
- Relates to #7150 Doc for upload thesausus from admin interface
<https://github.com/GeoNode/documentation/pull/88>
- Relates to #7194 Append data to layer
<https://github.com/GeoNode/documentation/pull/89>
- Refers to #7214 Sorting Thesauri
<https://github.com/GeoNode/documentation/pull/90>
- Relates to #6995 Documentation for ADVANCED_EDIT_EXCLUDE_FIELD
<https://github.com/GeoNode/documentation/pull/91>
Improving GeoNode Theme Library: introducing Jumbotron Slides
Implementation of an action to assign bulk permissions on layer to users
selected from People and/or Group Django admin forms enhancement #6582
<https://github.com/GeoNode/geonode/issues/6582>
Review of the current advanced resource workflow implementation
enhancement security #6551
<https://github.com/GeoNode/geonode/issues/6551>
File system operations do not adhere to Django file storage API
enhancement in progress #6414
<https://github.com/GeoNode/geonode/issues/6414>
Nav Toolbar gets distorted when multiple nav bar items are added by the
admin enhancement frontend major #6412
<https://github.com/GeoNode/geonode/issues/6412>
Allow only admins to edit/create keywords enhancement regression #6360
<https://github.com/GeoNode/geonode/issues/6360>
In home page show only ISO categories currently assigned to some dataset
enhancement frontend #6332
<https://github.com/GeoNode/geonode/issues/6332>
Modify the admin theme customisation feature to allow for the use of a
slide show in the home page enhancement feature frontend #6301
<https://github.com/GeoNode/geonode/issues/6301>
Improve GeoNode OpenID SP Protocol in order to be able to provide access
to external clients enhancement security #6273
<https://github.com/GeoNode/geonode/issues/6273>
Limit "maps using this layer" to maps the user has permission to see
enhancement security #6261
<https://github.com/GeoNode/geonode/issues/6261>
Prevent integrity errors on singleton model save enhancement #6223
<https://github.com/GeoNode/geonode/issues/6223>
Full list of Implemented GNIP
<https://github.com/GeoNode/geonode/issues?utf8=%E2%9C%93&q=is%3Aissue+is%3Aclosed+milestone%3A3.2+label%3Agnip>
Full List of Implemented Features
<https://github.com/GeoNode/geonode/issues?utf8=%E2%9C%93&q=is%3Aissue+is%3Aclosed+milestone%3A3.2+label%3Afeature>
Full list of Implemented Enhancements
<https://github.com/GeoNode/geonode/issues?page=1&q=is%3Aissue+is%3Aclosed+milestone%3A3.2+label%3Aenhancement&utf8=%E2%9C%93>
Full list of Dependencies Updates
<https://github.com/GeoNode/geonode/issues?q=is%3Aclosed+milestone%3A3.2+label%3Adependencies+>
Full list of Fixed Security Issues
<https://github.com/GeoNode/geonode/issues?q=is%3Aissue+is%3Aclosed+milestone%3A3.2+label%3Asecurity>
Full list of Fixed Security Pull Requests
<https://github.com/GeoNode/geonode/pulls?utf8=%E2%9C%93&q=is%3Apr+is%3Aclosed+label%3Asecurity+milestone%3A3.2+>
Full list of Resolved Regressions
<https://github.com/GeoNode/geonode/issues?utf8=%E2%9C%93&q=is%3Aissue+is%3Aclosed+milestone%3A3.2+label%3Aregression>
Full list of Fixed Critical Issues
<https://github.com/GeoNode/geonode/issues?utf8=%E2%9C%93&q=is%3Aissue+is%3Aclosed+milestone%3A3.2+label%3Ablocker>
Full list of Fixed Major Issues
<https://github.com/GeoNode/geonode/issues?utf8=%E2%9C%93&q=is%3Aissue+is%3Aclosed+milestone%3A3.2+label%3Amajor>
Full list of Fixed Minor Issues
<https://github.com/GeoNode/geonode/issues?utf8=%E2%9C%93&q=is%3Aissue+is%3Aclosed+milestone%3A3.2+label%3Aminor>
Full list of Updated Translations
<https://github.com/GeoNode/geonode/issues?utf8=%E2%9C%93&q=is%3Aissue+is%3Aclosed+milestone%3A3.2+label%3Atranslations>
All Closed Issues
<https://github.com/GeoNode/geonode/issues?q=is%3Aissue+is%3Aclosed+milestone%3A3.2>
Full Changelog
https://github.com/GeoNode/geonode/compare/3.1...3.2.0
<https://github.com/GeoNode/geonode/compare/3.1...3.2.x>
Il giorno ven 19 mar 2021 alle ore 17:08 Alessio Fabiani <
alessio.fabiani at geo-solutions.it> ha scritto:
> Dear Adrian,
> the changelog for 3.2.x is not yet complete. However I'm going to refresh
> it during the we. You will be able to find the updated version here
> <https://github.com/GeoNode/geonode/blob/3.2.x/CHANGELOG.md>
> The doc for upgrading is referring to the version 3.1 not the upcoming
> 3.1.1 or 3.2.0, so unless you are going to upgrade to the stable 3.1.0 that
> documentation might not be fully updated.
> I always suggest making a backup. If you are going to upgrade a production
> instance the best practice is typically cloning it to a staging server,
> upgrade, test and than switch the instances or repeat the upgrade steps
> carefully.
> Il giorno ven 19 mar 2021 alle ore 13:39 Adrian Bajer <bajeradr at gmail.com>
> ha scritto:
>> Thank you for your fast response!
>> I have same additional questions regarding upgrade of my GeoNode
>> instance:
>> 1. I have GeoNode 3.0 (manually installed) running on a
>> production-machine with Ubuntu 20.04LTS, GeoServer on a separate Tomcat,
>> separate PostgreSQL/PostGis, using UWSGI daemon.
>> If I want to upgrade to 3.1 or 3.2 should I follow that instruction:
>> https://docs.geonode.org/en/master/admin/upgrade/index.html#upgrade-from-2-10-x-3-0
>> switching and aligning the source code and the requirements.txt to the
>> 3.1.x branch?
>> 2. Is it necessary to make data backup before upgrading?
>> https://docs.geonode.org/en/master/intermediate/backup/index.html#full-geonode-backup-restore
>> 3. Is there a Change Log for version 3.2? (I want to know what will be
>> the most important changes in 3.2.)
>> Best regards,
>> *Adrian Bajer, MA*
>> *Department of Historical Atlas*
>> Institute of History, Polish Academy of Sciences
>> Rynek Starego Miasta 29/31
>> 00-272 Warsaw, Poland
>> e-mail: bajeradr at gmail.com
>> pt., 19 mar 2021 o 12:52 Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it> napisał(a):
>>> Dear Adrian,
>>> the branch 3.1.x is stable, we are backporting only few bug fixes and
>>> minor improvements.
>>> I just tested it both running docker from the root geonode and
>>> geonode-project and it works fine.
>>> 3.2.x is also relatively stable now, and we plan to release 3.2.0 soon.
>>> However keep in mind that 3.2.x has breaking changes, so you might need to
>>> do some manual work in order to adapt the old model to the new one.
>>> There's no upgrade guide available yet around unfortunately, but the
>>> process is not that hard (if you know how to do it).
>>> Just a big warning: both 3.1.x and 3.2.x are now relying a lot to
>>> asynchronous architecture, so accordingly to how you deployed your old
>>> versions, you might also install some new components as described here
>>> https://docs.geonode.org/en/master/install/advanced/core/index.html#enabling-fully-asynchronous-tasks
>>> You are still allowed to run everything synchronously, just pay
>>> attention to your settings.
>>> Regards,
>>> Alessio.
>>> Il giorno ven 19 mar 2021 alle ore 11:55 Adrian Bajer <
>>> bajeradr at gmail.com> ha scritto:
>>>> Dear all,
>>>> I need to upgrade instance of GeoNode in my Institute. Currently we
>>>> have GeoNode 3.0
>>>> According to recent information about changes in branches I have some
>>>> questions:
>>>> 1. Which branch is stable if I want to install version 3.1?
>>>> 2. When version 3.2 will be released? Maybe should I hold up my upgrade
>>>> until 3.2 release?
>>>> Best regards,
>>>> *Adrian Bajer, MA*
>>>> czw., 4 mar 2021 o 16:26 Alessio Fabiani <
>>>>> Dear devs,
>>>>> branches created on:
>>>>> - geonode {3.2.x, 3.1.x}
>>>>> - geonode-project {3.2.x, 3.1.x}
>>>>> deprecation messages put on:
>>>>> - geonode {3.x}
>>>>> - geonode-project {3.x}
>>>>> documentation updated
>>>>> - documentation {master --> 3.2.x; 3.x --> 3.1.x}
>>>>> Moreover:
>>>>> geonode/geonode-project 3.2.x now point to geonode-mapstore-client
>>>>> 2.1.x
>>>>> *WARNING 1: DO NOT USE MASTER BRANCH, IT WILL BE HIGHLY UNSTABLE*
>>>>> *WARNING 1: BUILD AND DEPLOYMENT TESTS STILL TO BE DONE ON NEW
>>>>> BRANCHES 3.1.x; 3.2.x *
>>>> _______________________________________________
>>>> geonode-devel mailing list
>>>> geonode-devel at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>> GeoServer Professional Services from the experts! Visit
>>> http://goo.gl/it488V for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> Founder/Technical Lead
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>>> phone: +39 0584 962313
>>> fax: +39 0584 1660272
>>> mob: +39 331 6233686
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>> This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20210409/cf81d889/attachment-0001.html>
More information about the geonode-devel
