[GeoNode-devel] Stability of branches during refactoring and cleanup
    Adrian Bajer
    bajeradr at gmail.com
    Fri Mar 19 05:39:04 PDT 2021
Thank you for your fast response!
I  have same additional questions regarding upgrade of my GeoNode instance:
1. I have GeoNode 3.0 (manually installed) running on a production-machine
with Ubuntu 20.04LTS, GeoServer on a separate Tomcat, separate
PostgreSQL/PostGis, using UWSGI daemon.
If I want to upgrade to 3.1 or 3.2 should I follow that instruction:
https://docs.geonode.org/en/master/admin/upgrade/index.html#upgrade-from-2-10-x-3-0
switching and aligning the source code and the requirements.txt to the
3.1.x branch?
2. Is it necessary to make data backup before upgrading?
https://docs.geonode.org/en/master/intermediate/backup/index.html#full-geonode-backup-restore
3. Is there a Change Log for version 3.2? (I want to know what will be the
most important changes in 3.2.)
Best regards,
*Adrian Bajer, MA*
*Department of Historical Atlas*
Institute of History, Polish Academy of Sciences
Rynek Starego Miasta 29/31
00-272 Warsaw, Poland
e-mail: bajeradr at gmail.com
pt., 19 mar 2021 o 12:52 Alessio Fabiani <alessio.fabiani at geo-solutions.it>
napisał(a):
> Dear Adrian,
> the branch 3.1.x is stable, we are backporting only few bug fixes and
> minor improvements.
> I just tested it both running docker from the root geonode and
> geonode-project and it works fine.
> 3.2.x is also relatively stable now, and we plan to release 3.2.0 soon.
> However keep in mind that 3.2.x has breaking changes, so you might need to
> do some manual work in order to adapt the old model to the new one.
> There's no upgrade guide available yet around unfortunately, but the
> process is not that hard (if you know how to do it).
> Just a big warning: both 3.1.x and 3.2.x are now relying a lot to
> asynchronous architecture, so accordingly to how you deployed your old
> versions, you might also install some new components as described here
> https://docs.geonode.org/en/master/install/advanced/core/index.html#enabling-fully-asynchronous-tasks
> You are still allowed to run everything synchronously, just pay attention
> to your settings.
> Regards,
> Alessio.
> Il giorno ven 19 mar 2021 alle ore 11:55 Adrian Bajer <bajeradr at gmail.com>
> ha scritto:
>> Dear all,
>> I need to upgrade instance of GeoNode in my Institute. Currently we have
>> GeoNode 3.0
>> According to recent information about changes in branches I have some
>> questions:
>> 1. Which branch is stable if I want to install version 3.1?
>> 2. When version 3.2 will be released? Maybe should I hold up my upgrade
>> until 3.2 release?
>> Best regards,
>> *Adrian Bajer, MA*
>> czw., 4 mar 2021 o 16:26 Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it> napisał(a):
>>> Dear devs,
>>> branches created on:
>>> - geonode {3.2.x, 3.1.x}
>>> - geonode-project {3.2.x, 3.1.x}
>>> deprecation messages put on:
>>> - geonode {3.x}
>>> - geonode-project {3.x}
>>> documentation updated
>>> - documentation {master --> 3.2.x; 3.x --> 3.1.x}
>>> Moreover:
>>> geonode/geonode-project 3.2.x now point to geonode-mapstore-client 2.1.x
>>> *WARNING 1: DO NOT USE MASTER BRANCH, IT WILL BE HIGHLY UNSTABLE*
>>> *WARNING 1: BUILD AND DEPLOYMENT TESTS STILL TO BE DONE ON NEW BRANCHES
>>> 3.1.x; 3.2.x *
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20210319/20dc81db/attachment-0001.html>
More information about the geonode-devel
