[GeoNode-devel] Stability of branches during refactoring and cleanup
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Fri Mar 19 04:52:01 PDT 2021
Dear Adrian,
the branch 3.1.x is stable, we are backporting only few bug fixes and minor
improvements.
I just tested it both running docker from the root geonode and
geonode-project and it works fine.
3.2.x is also relatively stable now, and we plan to release 3.2.0 soon.
However keep in mind that 3.2.x has breaking changes, so you might need to
do some manual work in order to adapt the old model to the new one.
There's no upgrade guide available yet around unfortunately, but the
process is not that hard (if you know how to do it).
Just a big warning: both 3.1.x and 3.2.x are now relying a lot to
asynchronous architecture, so accordingly to how you deployed your old
versions, you might also install some new components as described here
https://docs.geonode.org/en/master/install/advanced/core/index.html#enabling-fully-asynchronous-tasks
You are still allowed to run everything synchronously, just pay attention
to your settings.
Regards,
Alessio.
Il giorno ven 19 mar 2021 alle ore 11:55 Adrian Bajer <bajeradr at gmail.com>
ha scritto:
> Dear all,
> I need to upgrade instance of GeoNode in my Institute. Currently we have
> GeoNode 3.0
> According to recent information about changes in branches I have some
> questions:
> 1. Which branch is stable if I want to install version 3.1?
> 2. When version 3.2 will be released? Maybe should I hold up my upgrade
> until 3.2 release?
> Best regards,
> *Adrian Bajer, MA*
> *Department of Historical Atlas*
> Institute of History, Polish Academy of Sciences
> Rynek Starego Miasta 29/31
> 00-272 Warsaw, Poland
> e-mail: bajeradr at gmail.com
> czw., 4 mar 2021 o 16:26 Alessio Fabiani <alessio.fabiani at geo-solutions.it>
> napisał(a):
>> Dear devs,
>> branches created on:
>> - geonode {3.2.x, 3.1.x}
>> - geonode-project {3.2.x, 3.1.x}
>> deprecation messages put on:
>> - geonode {3.x}
>> - geonode-project {3.x}
>> documentation updated
>> - documentation {master --> 3.2.x; 3.x --> 3.1.x}
>> Moreover:
>> geonode/geonode-project 3.2.x now point to geonode-mapstore-client 2.1.x
>> *WARNING 1: DO NOT USE MASTER BRANCH, IT WILL BE HIGHLY UNSTABLE*
>> *WARNING 1: BUILD AND DEPLOYMENT TESTS STILL TO BE DONE ON NEW BRANCHES
>> 3.1.x; 3.2.x *
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20210319/12c3506a/attachment.html>
More information about the geonode-devel
