[GeoNode-devel] Cannot delete users after GeoNode upgrade
    Paolo Pasquali
    paolo.pasquali at gmail.com
    Mon Nov  8 00:33:32 PST 2021
Ciao Alessio,
That is the issue. Solved.
Thanks Alessio and Darko for your kind support.
Best,
Paolo
On Fri, Nov 5, 2021 at 6:12 PM Alessio Fabiani <
alessio.fabiani at geosolutionsgroup.com> wrote:
> Hi Paolo,
> please make sure you included this PR (
> https://github.com/GeoNode/geonode/pull/8297) with GeoNode 3.2.x core.
> On Fri, Nov 5, 2021 at 4:23 PM Paolo Pasquali <paolo.pasquali at gmail.com>
> wrote:
>> Hi devs,
>> I've upgraded a GeoNode 3.1.x to a 3.2. I've run the migrate command and
>> that seems to have caused an issue. While I try to delete a user I'm
>> getting the following:
>> Exception Type: ProgrammingError at /en/admin/people/profile/1013/delete/
>> Exception Value: relation "geonode_notificationreceiver" does not exist
>> LINE 1: ...ile"."language", "people_profile"."timezone" FROM "geonode_n...
>> Any idea on how to fix this?
>> Thanks for your help.
>> Best,
>> Paolo
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> Regards,
> Alessio Fabiani
> GeoServer Professional Services from the experts!
> Visit http://bit.ly/gs-services-us for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions Group
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39  333 8128928
> https://www.geosolutionsgroup.com/
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20211108/11497b63/attachment.html>
More information about the geonode-devel
