[GeoNode-devel] Cannot delete users after GeoNode upgrade
Alessio Fabiani alessio.fabiani at geosolutionsgroup.com
Fri Nov 5 10:11:59 PDT 2021
Hi Paolo,
please make sure you included this PR (
https://github.com/GeoNode/geonode/pull/8297) with GeoNode 3.2.x core.
On Fri, Nov 5, 2021 at 4:23 PM Paolo Pasquali <paolo.pasquali at gmail.com>
wrote:
> Hi devs,
> I've upgraded a GeoNode 3.1.x to a 3.2. I've run the migrate command and
> that seems to have caused an issue. While I try to delete a user I'm
> getting the following:
> Exception Type: ProgrammingError at /en/admin/people/profile/1013/delete/
> Exception Value: relation "geonode_notificationreceiver" does not exist
> LINE 1: ...ile"."language", "people_profile"."timezone" FROM "geonode_n...
> Any idea on how to fix this?
> Thanks for your help.
> Best,
> Paolo
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services-us for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions Group
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  333 8128928
https://www.geosolutionsgroup.com/
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20211105/7d7dd22a/attachment.html>
More information about the geonode-devel mailing list
