[GeoNode-devel] Geonode technical requirements
Stéphane Henriod
stephanebek at gmail.com
Thu Oct 28 04:18:49 PDT 2021
Many thanks Alessio, I had overlooked this page!
This information is perfectly sufficient for now :-)
All the best
Stéphane
Le jeu. 28 oct. 2021 à 13:03, Alessio Fabiani <
alessio.fabiani at geosolutionsgroup.com> a écrit :
> It is possible only to provide some minimal requirements as describe here
> https://docs.geonode.org/en/master/start/quick/index.html?highlight=ram#recommended-minimum-system-requirements
> But that one is only an indication; it really depends on a bunch of
> factors, like:
> - The type of installation you follow
> - The max number of concurrent requests you want to achieve (considering
> also tiled requests)
> - The amount of data you want to store (both on GeoNode and GeoServer)
> - The type of data you want to provide (e.g. there are Data Stores
> requiring a lot of DB connection available)
> and so on..
> On Thu, Oct 28, 2021 at 12:38 PM Stéphane Henriod <stephanebek at gmail.com>
> wrote:
>> Dear Geonode developers,
>> Where can I find information regarding the minimal technical requirements
>> for a server on which to install / deploy a GeoNode instance for a
>> productive system?
>> I fully acknowledge that the performances will be strongly related to the
>> amount of data processed by GeoNode, but maybe there are at least some
>> general guidelines on this?
>> So far I have not found anything in the documentation or on GitHub
>> Many thanks in advance (for your reply and for your amazing work on the
>> development of Geonode :-) )
>> Cheers
>> Stéphane
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> Regards,
> Alessio Fabiani
> GeoServer Professional Services from the experts!
> Visit http://bit.ly/gs-services-us for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions Group
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 333 8128928
> https://www.geosolutionsgroup.com/
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20211028/2b5d0151/attachment-0001.html>
More information about the geonode-devel
