[GeoNode-devel] Using a custom scheme @ gn4. How does it work?
Giovanni Allegri
giovanni.allegri at geosolutionsgroup.com
Thu Aug 25 06:41:34 PDT 2022
Hi Toni,
I completely missed this email.
I'm not very much into this topic. I suggest you to open an issue on GitHub
where Emanuele and Mattia (which implemented this) might read the request.
Giovanni
On Tue, Apr 26, 2022 at 12:05 PM Toni Schönbuchner <
toni.schoenbuchner at csgis.de> wrote:
> Dear all,
> I’m testing the promising new feature of custom metadata:
> https://docs.geonode.org/en/master/usage/extra_metadata/settings.html
> Therefore I’ve added the following in the extra metadata field in the
> wizard:
> https://master.demo.geonode.org/catalogue/#/dataset/879
> "field_name": "bike",
> "field_label": "KTM",
> "field_value": "ktm",
> "filter_header": "Sports Parameters"
> and would expect the data to be shown here:
> https://master.demo.geonode.org/datasets/geonode_master_data:geonode:tl_2018_02_anrc0/metadata_detail
> This as the template defines a block for it:
> https://github.com/GeoNode/geonode/blob/4535b87194685b72692ba58f6069ca675ee50ab8/geonode/maps/templates/layouts/map_panels.html#L536-L541
> Unfortunately neither the data is shown, nor the facet is added.
> Do I misuse or misunderstand this feature?
> Best
> Toni
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services-us for more information.
Dott. Giovanni Allegri
Technical Lead / Project Manager
GeoSolutions Group
phone: +39 0584 962313
cell: +39 345 2815774
fax: +39 0584 1660272
https://www.geosolutionsgroup.com/
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20220825/73bf1591/attachment.htm>
More information about the geonode-devel
