[GeoNode-devel] Using a custom scheme @ gn4. How does it work?
Toni Schönbuchner
toni.schoenbuchner at csgis.de
Thu Aug 25 22:43:00 PDT 2022
Hi Giovanni,
no problem! I will test this feature again with the current stable release and if needed
open an issue.
Best,
Toni
> Von: Giovanni Allegri <giovanni.allegri at geosolutionsgroup.com>
> Betreff: Aw: [GeoNode-devel] Using a custom scheme @ gn4. How does it work?
> Datum: 25. August 2022 um 15:41:34 MESZ
> An: Toni Schönbuchner <toni.schoenbuchner at csgis.de>
> Kopie: geonode-devel at lists.osgeo.org
> Hi Toni,
> I completely missed this email.
> I'm not very much into this topic. I suggest you to open an issue on GitHub where Emanuele and Mattia (which implemented this) might read the request.
> Giovanni
> On Tue, Apr 26, 2022 at 12:05 PM Toni Schönbuchner <toni.schoenbuchner at csgis.de <mailto:toni.schoenbuchner at csgis.de>> wrote:
> Dear all,
> I’m testing the promising new feature of custom metadata:
> https://docs.geonode.org/en/master/usage/extra_metadata/settings.html <https://docs.geonode.org/en/master/usage/extra_metadata/settings.html>
> Therefore I’ve added the following in the extra metadata field in the wizard:
> https://master.demo.geonode.org/catalogue/#/dataset/879 <https://master.demo.geonode.org/catalogue/#/dataset/879>
> "field_name": "bike",
> "field_label": "KTM",
> "field_value": "ktm",
> "filter_header": "Sports Parameters"
> and would expect the data to be shown here:
> https://master.demo.geonode.org/datasets/geonode_master_data:geonode:tl_2018_02_anrc0/metadata_detail <https://master.demo.geonode.org/datasets/geonode_master_data:geonode:tl_2018_02_anrc0/metadata_detail>
> This as the template defines a block for it:
> https://github.com/GeoNode/geonode/blob/4535b87194685b72692ba58f6069ca675ee50ab8/geonode/maps/templates/layouts/map_panels.html#L536-L541 <https://github.com/GeoNode/geonode/blob/4535b87194685b72692ba58f6069ca675ee50ab8/geonode/maps/templates/layouts/map_panels.html#L536-L541>
> Unfortunately neither the data is shown, nor the facet is added.
> Do I misuse or misunderstand this feature?
> Best
> Toni
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org <mailto:geonode-devel at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/geonode-devel <https://lists.osgeo.org/mailman/listinfo/geonode-devel>
> GeoServer Professional Services from the experts!
> Visit http://bit.ly/gs-services-us <http://bit.ly/gs-services-us> for more information.
> Dott. Giovanni Allegri
> Technical Lead / Project Manager
> GeoSolutions Group
> phone: +39 0584 962313
> cell: +39 345 2815774
> fax: +39 0584 1660272
> https://www.geosolutionsgroup.com/ <https://www.geosolutionsgroup.com/>
> http://twitter.com/geosolutions_it <http://twitter.com/geosolutions_it>
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20220826/73f1a46e/attachment.htm>
More information about the geonode-devel
