[GeoNode-devel] geonode-devel Digest, Vol 81, Issue 3
Ahmed Osman ahmednosman at cartologic.com
Tue Feb 22 00:51:40 PST 2022
Hello Pattara
CartoView is a django project for GeoNode plus some apps
Basically it is a different flavor of the same geonode
The GeoNode Code is unchanged and it is possible to upgrade GeoNode
GeoNode 4 uses a different presentation tier than the current release up to
3.3
We will run the CartoView Apps for Version 4 and forward as independent
apps not embedded in the Same Front End App that will be released for
GeoNode 4
So you will get the Version 4 GeoNode Front end as is and then some
additional apps now being decoupled
Hope this helps
Regards
Ahmed
On Tue, Feb 22, 2022 at 5:13 AM Pattara Kiatisevi <pattara at longdo.com>
wrote:
> Dear Ahmed,
> Thank you, we'll try it. Quick question: is Cartoview a fork, or just a
> wrapper to GeoNode?
> I mean if GeoNode 4 is out, can the embedded GeoNode in Cartoview be
> updated easily?
> Thank you very much,
> Pattara
> On Sun, Feb 20, 2022 at 1:22 PM Ahmed Osman <ahmednosman at cartologic.com>
> wrote:
>> Dear Pattara
>> 1- Exporting data from Geopackage
>> 2- Running Buffer analysis
>> Are already available in Cartoview, you can very quickly test it on
>> windows from the installer https://cartoview.net/download/
>> At least this should handle half your troubles
>> Best Regards
>> Ahmed Osman
>> On Sat, Feb 19, 2022 at 10:00 PM <geonode-devel-request at lists.osgeo.org>
>> wrote:
>>> Send geonode-devel mailing list submissions to
>>>         geonode-devel at lists.osgeo.org
>>> To subscribe or unsubscribe via the World Wide Web, visit
>>>         https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>> or, via email, send a message with subject or body 'help' to
>>> You can reach the person managing the list at
>>>         geonode-devel-owner at lists.osgeo.org
>>> When replying, please edit your Subject line so it is more specific
>>> than "Re: Contents of geonode-devel digest..."
>>> Today's Topics:
>>>    1. Questions on GeoNode (Pattara Kiatisevi)
>>> Message: 1
>>> Date: Sat, 19 Feb 2022 16:41:28 +0700
>>> From: Pattara Kiatisevi <pattara at longdo.com>
>>> To: geonode-devel at lists.osgeo.org
>>> Subject: [GeoNode-devel] Questions on GeoNode
>>> Message-ID:
>>>         <CAJM+N=u3mJq_3yPh0sfTjvFkcnx-QQOcac1i8BJBY=
>>> uj2ik4Kg at mail.gmail.com>
>>> Content-Type: text/plain; charset="utf-8"
>>> Hi GeoNode team,
>>> Thank you for creating such a wonderful product, esp. the new version 4
>>> looks really good!
>>> We are a Bangkok-based software company running Map API services (
>>> https://map.longdo.com/) for Thai suers. We plan to use
>>> GeoNode/Mapstore in
>>> customer projects, possibly with some customizations, and have a few
>>> questions just to make sure we are going in the right direction.
>>> 1. Importing of GeoPackage files seems not supported yet. Is it just not
>>> yet implemented or are there any big obstacles against supporting it?
>>> 2. Does GeoNode already have a concept or implementation of layer
>>> analysis,
>>> e.g., user picks a layer, do some actions e.g., create buffer, or merge
>>> it
>>> with another layer, then save as another new layer? If we are to do it,
>>> do
>>> you have suggestions on how it should be done?
>>> 3. The following plug-ins/feature of MapStore seem to disappear in the
>>> Mapstore that is embedded in GeoNode. Is it possible to enable them?
>>> * config search service / create,edit search service
>>> * export map application to mapstore config format, WMC format
>>> * import map context file: MapStore legacy format, WMC and vector layer
>>> files: shapefiles (must be contained in zip archives), KML/KMZ, GeoJSON,
>>> Annotations or GPX to map application
>>> * add/edit Catalog layer service
>>> 4. We have created a few custom plug-ins that adding something on the
>>> displaying map, but  those stuff won't be on the printed output. Any
>>> suggestions on how do we customize the printing module to include those
>>> things?
>>> Pattara
>>> -------------- next part --------------
>>> An HTML attachment was scrubbed...
>>> URL: <
>>> http://lists.osgeo.org/pipermail/geonode-devel/attachments/20220219/0b696409/attachment-0001.html
>>> Subject: Digest Footer
>>> End of geonode-devel Digest, Vol 81, Issue 3
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20220222/018247a6/attachment-0001.html>
More information about the geonode-devel mailing list
