[GeoNode-devel] GeoServer PROXY_BASE_URL setting
Alessio Fabiani
alessio.fabiani at geosolutionsgroup.com
Thu Jun 9 01:30:38 PDT 2022
If I recall correctly, that should be possible through the "ENV
PARAMETRIZATION"
https://docs.geoserver.org/stable/en/user/datadirectory/configtemplate.html#:~:text=Environment%20parametrization%20allows%20to%20parameterize,environment%20in%20which%20is%20run
Regards,
Alessio.
On Thu, Jun 9, 2022 at 9:56 AM Pattara Kiatisevi <pattara at longdo.com> wrote:
> Hi,
> Running GeoNode using Docker and behind an outer reverse proxy (that
> handles HTTPS and stuff), everytime I docker-compose build and up -d, I
> have to go into the container to edit GeoServer's
> /usr/local/tomcat/tmp/webapps/geoserver/WEB-INF/web.xml and add something
> like this to make it work with the https URL.
> <context-param>
> <param-name>PROXY_BASE_URL</param-name>
> <param-value>http://82.58.146.45/geoserver</param-value>
> </context-param>
> Just wonder if there is a convenient variable in .env that one can set
> before bulding and have the PROXY_BASE_URL set automagically?
> Thank you very much,
> Pattara
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services-us for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions Group
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 333 8128928
https://www.geosolutionsgroup.com/
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20220609/05590c5c/attachment.htm>
More information about the geonode-devel
