[GeoNode-devel] GeoServer PROXY_BASE_URL setting
Pattara Kiatisevi pattara at longdo.com
Sat Jun 11 03:28:39 PDT 2022
In geonode/geoserver docker, the option seems to be already on.
 877086 ?        Ssl    1:15 /usr/local/openjdk-8/bin/java
-Djava.util.logging.config.file=/usr/local/tomcat/conf/logging.properties
-Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
-Djava.awt.headless=true -Xms2G -Xmx4G -XX:+UnlockDiagnosticVMOptions
-XX:+LogVMOutput -XX:LogFile=/var/log/jvm.log
-XX:PerfDataSamplingInterval=500 -XX:SoftRefLRUPolicyMSPerMB=36000
-XX:-UseGCOverheadLimit -XX:+UseConcMarkSweepGC -XX:+UseParNewGC
-XX:ParallelGCThreads=4 -Dfile.encoding=UTF8
-Djavax.servlet.request.encoding=UTF-8
-Djavax.servlet.response.encoding=UTF-8 -Duser.timezone=GMT
-Dorg.geotools.shapefile.datetime=false -DGEOSERVER_CSRF_DISABLED=true
-DPRINT_BASE_URL=http://geoserver:8080/geoserver/pdf
-DALLOW_ENV_PARAMETRIZATION=true
-Xbootclasspath/a:/usr/local/tomcat/webapps/geoserver/WEB-INF/lib/marlin-0.9.3-Unsafe.jar
-Dsun.java2d.renderer=org.marlin.pisces.MarlinRenderingEngine
-Djdk.tls.ephemeralDHKeySize=2048
-Djava.protocol.handler.pkgs=org.apache.catalina.webresources
-Dorg.apache.catalina.security.SecurityListener.UMASK=0027
-Dignore.endorsed.dirs= -classpath
/usr/local/tomcat/bin/bootstrap.jar:/usr/local/tomcat/bin/tomcat-juli.jar
-Dcatalina.base=/usr/local/tomcat -Dcatalina.home=/usr/local/tomcat
-Djava.io.tmpdir=/usr/local/tomcat/temp
org.apache.catalina.startup.Bootstrap start
However, creating a geoserver-environment.properties file in the data_dir
(/geoserver_data/data/) with contents like this doesn't seem to work.
PROXY_BASE_URL=https://marine2.longdo.com/
Another way I could mount the web.xml file as external volume?
Any hints are appreciated,
Pattara
On Thu, Jun 9, 2022 at 3:30 PM Alessio Fabiani <
alessio.fabiani at geosolutionsgroup.com> wrote:
> If I recall correctly, that should be possible through the "ENV
> PARAMETRIZATION"
> https://docs.geoserver.org/stable/en/user/datadirectory/configtemplate.html#:~:text=Environment%20parametrization%20allows%20to%20parameterize,environment%20in%20which%20is%20run
> Regards,
> Alessio.
> On Thu, Jun 9, 2022 at 9:56 AM Pattara Kiatisevi <pattara at longdo.com>
> wrote:
>> Hi,
>> Running GeoNode using Docker and behind an outer reverse proxy (that
>> handles HTTPS and stuff), everytime I docker-compose build and up -d, I
>> have to go into the container to edit GeoServer's
>> /usr/local/tomcat/tmp/webapps/geoserver/WEB-INF/web.xml and add something
>> like this to make it work with the https URL.
>>     <context-param>
>>       <param-name>PROXY_BASE_URL</param-name>
>>       <param-value>http://82.58.146.45/geoserver</param-value>
>>     </context-param>
>> Just wonder if there is a convenient variable in .env that one can set
>> before bulding and have the PROXY_BASE_URL set automagically?
>> Thank you very much,
>> Pattara
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> Regards,
> Alessio Fabiani
> GeoServer Professional Services from the experts!
> Visit http://bit.ly/gs-services-us for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions Group
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39  333 8128928
> https://www.geosolutionsgroup.com/
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20220611/bc412ac3/attachment.htm>
More information about the geonode-devel mailing list
