[GeoNode-devel] GeoServer PROXY_BASE_URL setting
Alessio Fabiani alessio.fabiani at geosolutionsgroup.com
Sun Jun 12 23:27:49 PDT 2022
Hi Pattara,
try to put the name of the variable ${PROXY_BASE_URL} into the global.xml
file instead of a fixed value and restart GeoServer.
That should work.
Alessio.
On Sat, Jun 11, 2022 at 12:28 PM Pattara Kiatisevi <pattara at longdo.com>
wrote:
> In geonode/geoserver docker, the option seems to be already on.
>  877086 ?        Ssl    1:15 /usr/local/openjdk-8/bin/java
> -Djava.util.logging.config.file=/usr/local/tomcat/conf/logging.properties
> -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager
> -Djava.awt.headless=true -Xms2G -Xmx4G -XX:+UnlockDiagnosticVMOptions
> -XX:+LogVMOutput -XX:LogFile=/var/log/jvm.log
> -XX:PerfDataSamplingInterval=500 -XX:SoftRefLRUPolicyMSPerMB=36000
> -XX:-UseGCOverheadLimit -XX:+UseConcMarkSweepGC -XX:+UseParNewGC
> -XX:ParallelGCThreads=4 -Dfile.encoding=UTF8
> -Djavax.servlet.request.encoding=UTF-8
> -Djavax.servlet.response.encoding=UTF-8 -Duser.timezone=GMT
> -Dorg.geotools.shapefile.datetime=false -DGEOSERVER_CSRF_DISABLED=true
> -DPRINT_BASE_URL=http://geoserver:8080/geoserver/pdf -DALLOW_ENV_PARAMETRIZATION=true
> -Xbootclasspath/a:/usr/local/tomcat/webapps/geoserver/WEB-INF/lib/marlin-0.9.3-Unsafe.jar
> -Dsun.java2d.renderer=org.marlin.pisces.MarlinRenderingEngine
> -Djdk.tls.ephemeralDHKeySize=2048
> -Djava.protocol.handler.pkgs=org.apache.catalina.webresources
> -Dorg.apache.catalina.security.SecurityListener.UMASK=0027
> -Dignore.endorsed.dirs= -classpath
> /usr/local/tomcat/bin/bootstrap.jar:/usr/local/tomcat/bin/tomcat-juli.jar
> -Dcatalina.base=/usr/local/tomcat -Dcatalina.home=/usr/local/tomcat
> -Djava.io.tmpdir=/usr/local/tomcat/temp
> org.apache.catalina.startup.Bootstrap start
> However, creating a geoserver-environment.properties file in the data_dir
> (/geoserver_data/data/) with contents like this doesn't seem to work.
> PROXY_BASE_URL=https://marine2.longdo.com/
> Another way I could mount the web.xml file as external volume?
> Any hints are appreciated,
> Pattara
> On Thu, Jun 9, 2022 at 3:30 PM Alessio Fabiani <
> alessio.fabiani at geosolutionsgroup.com> wrote:
>> If I recall correctly, that should be possible through the "ENV
>> PARAMETRIZATION"
>> https://docs.geoserver.org/stable/en/user/datadirectory/configtemplate.html#:~:text=Environment%20parametrization%20allows%20to%20parameterize,environment%20in%20which%20is%20run
>> Regards,
>> Alessio.
>> On Thu, Jun 9, 2022 at 9:56 AM Pattara Kiatisevi <pattara at longdo.com>
>> wrote:
>>> Hi,
>>> Running GeoNode using Docker and behind an outer reverse proxy (that
>>> handles HTTPS and stuff), everytime I docker-compose build and up -d, I
>>> have to go into the container to edit GeoServer's
>>> /usr/local/tomcat/tmp/webapps/geoserver/WEB-INF/web.xml and add something
>>> like this to make it work with the https URL.
>>>     <context-param>
>>>       <param-name>PROXY_BASE_URL</param-name>
>>>       <param-value>http://82.58.146.45/geoserver</param-value>
>>>     </context-param>
>>> Just wonder if there is a convenient variable in .env that one can set
>>> before bulding and have the PROXY_BASE_URL set automagically?
>>> Thank you very much,
>>> Pattara
>>> geonode-devel mailing list
>>> geonode-devel at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>> Regards,
>> Alessio Fabiani
>> GeoServer Professional Services from the experts!
>> Visit http://bit.ly/gs-services-us for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions Group
>> phone: +39 0584 962313
>> fax:     +39 0584 1660272
>> mob:   +39  333 8128928
>> https://www.geosolutionsgroup.com/
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
Regards,
Alessio Fabiani
@alfa7691
GeoSolutions Group
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20220613/bda80a7c/attachment.htm>
More information about the geonode-devel mailing list
