[GeoNode-devel] GeoNode 4.0.0rc0 + Keycloak
Pattara Kiatisevi
pattara at longdo.com
Wed May 25 01:44:00 PDT 2022
Changing back to django-allauth 0.44.0 seems to solve the problem at the
moment.
$ git diff requirements.txt
diff --git a/requirements.txt b/requirements.txt
index 50c578230..be55ef0e8 100644
--- a/requirements.txt
+++ b/requirements.txt
@@ -27,7 +27,8 @@ rdflib==6.1.1
smart_open==6.0.0
# Django Apps
-django-allauth==0.50.0
+#django-allauth==0.50.0
+django-allauth==0.44.0
django-appconf==1.0.5
django-celery-results==2.3.1
django-filter==21.1
Cheers,
Pattara
On Fri, May 6, 2022 at 7:32 PM Giovanni Allegri <
giovanni.allegri at geosolutionsgroup.com> wrote:
> Thanks for reporting this Pattara.
> We have used Keyclok in several contexts in the past but we haven't had
> the chance to test it with GN 4 yet.
> Would you kindly open an issue on the GeoNode repo to keep track of it?
> Best,
> Giovanni
> On Thu, May 5, 2022 at 12:03 PM Pattara Kiatisevi <pattara at longdo.com>
> wrote:
>> Hi,
>> We used to set up a GeoNode 3.3x + Keycloak site according to
>> https://gist.github.com/t-book/0fb30804e217bdeb064dd91b5041fbc9 and
>> things worked well.
>> Now as we are trying GeoNode 4.0.0rc0, following the same steps. But when
>> clicking at the "Sign in with Keycloak" link (which is something like
>> https://<keycloak-hostname>/account/keycloak/login/?process=login&next=%2F
>> ), it doesn't redirect the user to the Keycloak site, but instead got stuck
>> at geonode.
>> When checking that URL, we found that if the request is made with HEAD
>> (i.e., curl -I), the response seems to be correct (HTTP 302, redirecting
>> users to Keycloak).
>> [image: image.png]
>> But when using browsers or normal curl (curl -v -o /dev/null "https://<geonode-hostname>/account/keycloak/login/?process=login&next=%2F",
>> it responds with HTTP 200, which is wrong.
>> [image: image.png]
>> Any input is really appreciated.
>> Thank you very much in advance,
>> Pattara
>> geonode-devel mailing list
>> geonode-devel at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> GeoServer Professional Services from the experts!
> Visit http://bit.ly/gs-services-us for more information.
> Dott. Giovanni Allegri
> Technical Lead / Project Manager
> GeoSolutions Group
> phone: +39 0584 962313
> fax: +39 345 2815774
> https://www.geosolutionsgroup.com/
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20220525/7c603a2d/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20220525/7c603a2d/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20220525/7c603a2d/attachment-0003.png>
More information about the geonode-devel
