[GeoNode-devel] GeoNode 4.0.0rc0 + Keycloak
Giovanni Allegri giovanni.allegri at geosolutionsgroup.com
Fri May 6 05:32:11 PDT 2022
Thanks for reporting this Pattara.
We have used Keyclok in several contexts in the past but we haven't had the
chance to test it with GN 4 yet.
Would you kindly open an issue on the GeoNode repo to keep track of it?
Best,
Giovanni
On Thu, May 5, 2022 at 12:03 PM Pattara Kiatisevi <pattara at longdo.com>
wrote:
> Hi,
> We used to set up a GeoNode 3.3x + Keycloak site according to
> https://gist.github.com/t-book/0fb30804e217bdeb064dd91b5041fbc9 and
> things worked well.
> Now as we are trying GeoNode 4.0.0rc0, following the same steps. But when
> clicking at the "Sign in with Keycloak" link (which is something like
> https://<keycloak-hostname>/account/keycloak/login/?process=login&next=%2F
> ), it doesn't redirect the user to the Keycloak site, but instead got stuck
> at geonode.
> When checking that URL, we found that if the request is made with HEAD
> (i.e., curl -I), the response seems to be correct (HTTP 302, redirecting
> users to Keycloak).
> [image: image.png]
> But when using browsers or normal curl (curl -v -o /dev/null "https://<geonode-hostname>/account/keycloak/login/?process=login&next=%2F",
> it responds with HTTP 200, which is wrong.
> [image: image.png]
> Any input is really appreciated.
> Thank you very much in advance,
> Pattara
> geonode-devel mailing list
> geonode-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services-us for more information.
Dott. Giovanni Allegri
Technical Lead / Project Manager
GeoSolutions Group
phone: +39 0584 962313
fax:      +39 345 2815774
https://www.geosolutionsgroup.com/
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20220506/f2d8dbbb/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20220506/f2d8dbbb/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20220506/f2d8dbbb/attachment-0003.png>
More information about the geonode-devel mailing list
